How do i port forward on the N4PROUTER i got no clue how and no manual to boot
SOURCE: my n4prouter set up
Connect a computer to the router via Ethernet cable, then you should be
able to log into the router to set it up by opening a web
browser and putting "http://192.168.1.1/" or "http://192.168.0.1/"
(without the quotes) into the address line. The default username and
password is usually "admin" and "admin" or username "admin" with no
password. From there you should be able to configure the router and
retrieve or change the WEP key.
Let us know how you make out.
SOURCE: n4prouter
This is a quick fix to your problem.
Go into the xbox live network configuration and manually set the IP address there.
The IP address consists of 4 octets (4 sets of numbers) separated by periods.
You will only want to change the last number.
For instance, if the current IP address is 192.168.1.3 you would only change the 3.
I would suggest using a number like 237 to avoid conflicting with the other computers and devices on the network.
Let me know how it goes.
SOURCE: My N4PROUTER isnt working :(
isolate your problem. maybe it has something to do with your computer. try connection your pc directly to your modem. if it gets online there. the problem is with your router. try unplugging and replugging your router then restart your pc.
SOURCE: problems getting a connection with vista operating system
This could possibly be an issue with the drivers provided by vista for your NIC. Try looking for updates for it or just tell me the model name of it.
