The ignition lock anti-theft switch (19A438) detects if the ignition key cylinder is broken or "slam pulled" during a theft. The ignition lock anti-theft switch is always monitored by the remote anti-theft personality (RAP) module. This allows the alarm system to be triggered in the case that the ignition lock anti-theft switch detects tampering of the ignition key cylinder (even in the event that the alarm is not active at the time).
Refer to the Section 501-14B for more details on the keyless entry remote transmitter (15K601).
The door open warning lamp switch (14018) communicates to the RAP module through the generic electronic module (GEM). This input to the RAP will cause the anti-theft alarm to be sounded if the anti-theft alarm was armed.
The door disarm switches are assembled into both LH and RH lock sets. The door disarm switch must be triggered before the mechanical lock unlocks. This is to prevent the anti-theft alarm from activating when it should have been disarmed.
The RAP module controls the anti-theft system and is the brains of the keyless entry system. The RAP module communicates with the GEM to request that the interior lights be turned ON/OFF with use of the keyless entry remote transmitter, and the GEM communicates to the RAP to inform when the door is opened. Refer to Section 418-00 for inter-module communication.
The RAP module has three wire connectors attached to it:
- The antenna for the keyless entry remote transmitter.
- 26 circuit connector (C256).
- 22 circuit connector (C257).
In addition to the perimeter alarm that uses the door open warning lamp switch, the RAP module also uses the ignition lock anti-theft switch and the autolock/relock feature to prevent theft of the vehicle. For a full description of the autolock/relock system, refer to Section 501-14B .
The THEFT LED is found on the instrument panel between the tachometer scale and the needle pivot point. The LED is illuminated during prearming and flashes when armed or triggered.
Prearming and Arming the System
The system can be armed if:
- The ignition is OFF.
- The PANIC alarm is OFF.
- All doors are closed.
There are two ways to prearm the system:
- Press the LOCK button on the transmitter.
- Open a door, press the power door lock button and close the door.
After 30 seconds the system will be armed and the theft indicator in the cluster will flash every two seconds.
Disarming an Untriggered System
An armed system will be disarmed with one of these valid actions:
- Pressing the UNLOCK button on the transmitter.
- Placing a key in the door and turning to UNLOCK.
- Turning the key to RUN or ACC.
The anti-theft alarm can be triggered by the following conditions:
- The ignition cylinder is damaged with or without the RAP being armed.
- A door is opened without disarming the armed RAP module.
The remote transmitter can activate a panic alarm which is similar to an anti-theft alarm, but does not deactivate the starter or cause the theft indicator to flash.
Disarming a Triggered System
If the system has been triggered, (the horn honks, the lights flash, and an external starter interrupt relay is engaged), the system can be disarmed by:
- Pressing the UNLOCK or PANIC button on the transmitter.
- Putting a key in the door and unlocking the door.
- Turning the ignition to RUN/ACC (Turning the key to RUN/ACC will not disarm an alarm that has been triggered by the ignition lock anti-theft switch.).
Does a 1997 lantra wagon have a anti syphon system in the full tank?
I have a 2008 toyota 4runner XSP model with 80k miles.. My wife was driving down the road and car just cut off. It would not crank back up it tried.. Then cut right back off everytime.. I had to get it pulled home. I was told it was getting some code saying something about anti theft system locking it out?
I have a 2008 toyota 4runner XSP car cut off while wife was driving. We tried to crank runs for 3seconds then turns back off. had to get pulled home. Tring to see if something I can do before going to toyota.. Help
Can I deactivate the theft system on my 94 mustang to start it
