Well, sir, it is metal on metal, and you did well to stop it. Someone will be needing to take the whole thing apart and find the problem. It may be easy because the metal should show where it was rubbing because it will be shiny bright.
Be blessed.
A loud screeching sound from your dryer could be caused by a few different issues. Here are a few things you can check:
Belt: A worn or broken belt can cause a loud screeching sound. To check this, unplug the dryer and remove the front panel. Look for any signs of wear or damage to the belt. If it looks worn or broken, you'll need to replace it.
Drum Rollers: Dryer drum rollers can also cause a loud screeching noise. You can check this by turning the drum by hand. If it feels rough or wobbles, the rollers may be worn and need to be replaced.
Idler Pulley: A faulty idler pulley can cause a screeching noise. You can check this by removing the belt and spinning the pulley by hand. If it feels rough or wobbles, it may need to be replaced.
Motor: A motor that is failing can also cause a loud screeching noise. You can check this by turning the drum by hand and listening for any unusual sounds coming from the motor.
If you're not comfortable checking these components yourself, it's best to call a professional to diagnose and repair the issue.
A dryer kit contains the wheels that the drum turns on, new glides, to keep the drum in place, and a tension pulley for the belt. You may also need a rear bearing. I'd say about $60 in parts and an hour or two & you'd be good to go.
There are 2 wheels in the rear that the drum rotates on - one could be binding. The tensioner has a wheel, check it for rotation. Belt slipping? Check motor for operation - check that plastic blower isn't rubbing in its box. Dryers are easy to disassemble - check YouTube for procedure.
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
