HP Officejet Pro 8500A Wireless All-in-One Inkjet Printer Logo
Gina Genz-Giannoni Posted on Jan 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rollers not picking up the paper or picking too many pieces at once.
I tried doing a diagnostic test with the hp website, but that didn't help. I cleaned the inside with the electronic spray thoroughly, and it still makes weird noises and rollers aren't picking up paper properly.
anil
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Feb 13, 2015
anil
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
7601
Points
26
U can under stand that not picking problem..its com.on problem in all printers having 920 cartridges.small black gear attached to the rod shifted a side from it's original position ..lhv solved many printers like wide formate 7000.6500 plus, oj 6500w, u need the hnician to take out that main printer assly and fix the gear with instant glue.The gear driving the pickup unit(which u can see hang abv the paper tray) just slide 3-4 mm.god luck.100./.solved problem
spool32
Level 2:
New Friend:
  • Expert 73 Answers
  • Posted on Jan 08, 2014
spool32
Expert
Level 2:
New Friend:
Answers
73
Questions
0
Helped
11848
Points
168
Pickup rollers can be easily replaced if you want to try that first. But the other noises could point to stripped gears or a different problem internally
1 Related Answer
Anonymous
  • 610 Answers
  • Posted on Aug 11, 2011
SOURCE: Not receiving faxes when generated
Are you using wireless or wired connection? Try to uninstall and re-install your printer. Remove all traces of the printer in Printers and devices including the fax. Go to add/remove programs and uninstall all applications that came with the printer. Reboot the computer. Unplug the printer from the PC and turn it off.
Run the CD that came with the printer and install all application and drivers. Wait for the installation to prompt you to plug the printer and turn it on. Make sure to wait for the prompt before plugging the printer to avoid your Operating System to use it's Native Drivers rather than the supplied driver from HP. Make sure that you are using wired connection when setting the printer up.
Hope this works for you.
How do I fix a Canon MP460 printer that feeds multiple sheets at a time, even for a one-page document, causing a paper jam?
Assumed you have cleaned out the feeding slot and sprockets that turn the feeder wheels. Often there's some piece of paper or gunk. One option that likely applies to most printers -- from another HP online source: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00190540&cc=us&dlc=en&lc=en
  1. Look for paper that might have jammed inside the product. Use a flashlight to carefully view the areas around the rollers. Remove all traces of paper found.
  2. Wipe the rubber paper-feed rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers up carefully to clean all the way around.
  1. Look for the paper pick roller farther inside the rear access area. The paper pick roller
    IMPORTANT : The paper pick roller is a bit more difficult to reach; however, it is the most important part to clean. Make sure to clean it thoroughly. If this roller is not clean, the issue will likely continue.
  2. Clean the paper pick roller with a cotton swab moistened with distilled or bottled water. Apply a moderate amount of pressure to make sure that you remove all debris. Clean the roller thoroughly all the way around. Figure 8: Clean the paper pick roller
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/855/c01996641.gif" alt="Photo of cleaning the paper pick roller." title="Photo of cleaning the paper pick roller.">
  3. Make sure that the rollers on the rear access door or duplexer are clean and in good condition. If any are missing, stuck, or loose, replace the rear access door or duplexer with a new one. Figure 9: Rear access door rollers
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/968/c01977887.gif" alt="Graphic of the rear access door and paper rollers" title="Graphic of the rear access door and paper rollers">
  4. Allow the rollers to dry completely, and then replace the rear access door or duplexer. Slide the rear access door or duplexer into place, and then gently push it in until it clicks or snaps into place.
Hp officejet 4500 will not print from mac ibook g4
HP Officejet 4500 (G510) Series and 4500 (K710) Series All-in-One Printers - The All-in-One Does Not Pick Up or Feed Paper Issue The product does not pick up or feed paper from the paper tray. How to use the solutions in this document To resolve the issue, try each solution in this document in the order presented. c01733891.gif IMPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware is functioning correctly. To print a self-test report, use the steps in the following table. How to print a self-test report
  1. Load plain, white paper in the paper tray.
  2. Press and hold the Cancel button (c01235250.gif ) on the product control panel.
  3. While holding the Cancel button (c01235250.gif ), press the OK button (c01961874.gif ). The self-test report prints.
NOTE: Refer back to the steps in this table after attempting each solution. Solution one: Reset the All-in-One
  1. Disconnect the power cord from the back of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the back of the product.
  4. Press the Power button (c01602202.gif ) to turn on the product.
  5. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the test page prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the test page does not print , continue with the next solution.
Solution two: Check the paper The condition of the paper or the amount of paper loaded might prevent the rollers from picking it up and feeding it through the product. Use the following steps to check the paper in the input tray.
  1. Remove any wrinkled or damaged paper from the input tray.
  2. Make sure that all the paper is the same size and type.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper contains from 10 to 25 sheets of paper.
    NOTE: Do not overload the input tray. Make sure the stack of paper is shorter than the top of the paper width guide.
  5. Insert the stack of paper into the product, and then gently push the paper width guide snugly against the paper. Figure 1: Load paper c01970609.gif 1 - Load paper 2 - Adjust the paper width guide Illustration of loading paper and adjusting the paper width guide
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution three: Check the print settings The paper settings in the print driver must match the paper size and type loaded in the product. Use the following instructions to adjust the paper settings.
  1. In the software program you are printing from, click File .
  2. Click Print , and then click Setup , Properties , or Preferences .
    NOTE: The specific options might vary depending on the software program.
  3. Click the Features tab.
  4. In the Basic Options pane, select More from the Paper sizes drop-down list.
  5. Select the size of paper loaded in the product, and then click OK .
  6. In the Basic Options pane, select More from the Paper type drop-down list.
  7. Select the type of paper that you loaded, and then click OK .
    NOTE: These changes do not change the default print settings. The print settings revert to the default settings the next time you open the program.
  8. Change any other print settings necessary, and then click OK .
  9. Click OK to print.
  10. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution four: Clean the rollers Follow these steps to clean the rear rollers and the pick rollers on the HP product. Step One: Clean the rear rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 2: Remove the rear access door c01961876.gif Remove the rear access door
  4. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the paper rollers. Rotate the rollers with your fingers to clean all the way around. Figure 3: Clean the rollers c00246512.jpg Graphic: Showing paper rollers
  5. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely. Figure 4: Access door rollers c01590938.gif Access door rollers
  6. Allow the rollers to dry completely.
  7. Reattach the rear access door. Push the door forward until it snaps into place.
Step two: Clean the pick roller
  1. Remove any paper from the paper tray.
  2. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 5: Remove the rear access door c01961876.gif Remove the rear access door Figure 6: Rear rollers and location of pick roller c01976220.gif Image: Rear rollers and location of pick roller
  3. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the pick roller. Rotate the pick roller upward with your fingers to clean all the way around. Figure 7: Pick roller c01975068.gif Image: Pick roller in the product
  4. Make sure that the pick roller and the rollers around it are clean, free of paper bits, and rotate freely.
  5. Allow the pick roller to dry completely.
  6. Reattach the rear access door. Push the door forward until it snaps into place.
  7. Load the tray with plain white paper.
  8. Reconnect the power cord to the rear of the product.
  9. Press the Power button (c01602202.gif ) to turn on the product.
Solution five: Service the All-in-One
PAPER NOT RECIVE
Paper not picking up?..shoot print command and observe printer trying to grabbing the paper?..see any marks on paper leading edge? Remove cartridge and see inside paper pick up roller,might be its dusty or warn out, remove the pick up roller releasing the side locks, clean with wet cloth, fix it back then try once, if its success..end the process.. if not replace pick up roller..observe similar kind of machine: 2_4_2012_9_32_43_am.gif2_4_2012_9_33_08_am.jpg
Hp larser jet 3050 : DISPLAY SAYS NO PAPER PICK UP HOW TO REMOVE TORN PAPER
switch off your priner. open the toner cover and remove the toner cartridge.you can see the jammed paper in the bck of pick up roller .remove any pieces of paper and try
My HP Deskjet 1220C printer picks up several pieces of paper when only printing 1 page. Picking up multiple pages when ony printing 1 page.
THE SPERATION PAD IS DIRTY OR WORN.TRY CLEANING THE SEP PAD WITH NAIL POLISH REMOVER.THE SEP PAD IS LOCATED UNDER THE ROLLER THAT PICKS UP THE PAPER
1helpful
Roller no longer picks up paper
Check to make sure that the rollers are not just sliding on the paper instead of gripping it. If this is the case, one thing you can try is to get some rubbing alcohol and cotton swab the rollers to make sure they are clean. Be sure to power down the copier first and unplug it.
Over time, the paper fibers build up on the rollers, and eventually, they get worn out. Cleaning them once in a while can prolong their lives and sometimes even revive "dead" rollers.
Also, let the alcohol dry before you try using the copier again.
Hope this helps!
More than piece it gets jammed
The problem is generally associated with the pickup roller ( roller that rotates and pulls the paper from the tray ), and the separation pad, ( a stationary cork like material.) It sounds like you need to replace both.. The concept is like wetting your two fingers to separate pages, except in this case it is a cork base and roller that do the work..
You can alternately try to rough up the cork very lightly with sand paper, and clean the roller. The pick-up roller should have some slight ribbing, and if it is all gone, a new roller is necessary. As a temporary fix is just that..temporary.
3answers
HP 3300
This procedure is described relating to a different error, but it resets and clears everything and would be worth a try http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=66359&prodTypeId=18972&prodSeriesId=66359&objectID=bpl10206 hp says for your specific error: "Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge." here is the complete guide to all the above http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=66359&prodTypeId=18972&prodSeriesId=66359&objectID=bpl11283 ask again if you need more Hope this helps :)
k24674
Grand Canyon Tech
Grand Canyon Tech
