I am using a Honeywell 3800G 14E scanner to try to scan mfg UPC codes onto an excel document and it will not pick up the full code and seems to be doing other strange things when I scan. Any thoughts? The scanner works when I use it in my POS system.....
SOURCE: HHP 3800 barcode scanner won't scan/read - I think
Ok I have found some info here what you need to do is download the correct driver from this site, install and you should be fine. HHP 3800r? is that the right one?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=165
This one below is for the HHP 3800r ?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=140
SOURCE: Programming the scanner for Quickbooks POS 8.0
Maybe you can find the right parameters in the user guide. It's available here: http://www.geoti.co.kr/DATA/hhp/IT3800_3900%20Users%20Guide.pdf
Hope it helps!
Best regards!
Rafael
