Electric Razor Pocket Rocket Ride-on Motorcycle Logo
E
Ed Leon Posted on Jan 08, 2014
Pocket rocket charger says its fully charged, but its really not
What could be the problem if my son dirt bike says its fully chaged but when he turns the throttle nothing happens
Did the socket the charger was plugged into actually have 120vac in the socket?
Or are you sure the charger is actually working? Is there a short so that the battery is draining as fast or faster than the charger is providing a charge?
Does switch need to be on when charging a razor pocket rocket?
No. The switch should be off before connecting the charger.
You can download a manual from Razor here...
http://www.razor.com/customer-care/owners-manuals/
How do you charge a razor pocket mini motorcycle
You use the supplied charger, or if you got it used without a charger, you can buy one here: Replacement Razor Pocket Rocket PR200 Scooter Battery Charger Adapter... After that, you plug the charger into the wall securely, and pull down on the round cover next to the motorcycles power button until it opens. Then plug the other end of the charger into the motorcycle.
3answers
1helpful
I have charged my MX 500 dirt rocket for 24 hours and the charger still is red. I took it off the charger and the back wheel went, but not going fast enough to stay up with both my feet off. When I hold...
The battery is probably bad. If a battery is fully discharged it can damage one of the cells in the battery. If you can replace the bad cell then it should charge correctly. Many of these batteries are made to be hard to open up and are hard to repair when they are opened. My best solution is to replace the battery and if that doesn't help then the charger is bad. When the charger is replaced then if both batteries are good then you will have a spare. I hope this helps.
2helpful
2answers
The bike never gets to full speed and fades fast
This is a battery problem. It needs replacement. There is likely a dead cell. Usually this happens from improper charge or not fully discharging.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
6helpful
3answers
The motorcycle dosn't run
You probably need a new battery. It is not uncommon for them to just be dead one day .  Check the razr website for replacement parts.  Thanks!
3answers
Top Electric Toys Experts
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Electric Toy Expert? Answer questions, earn points and help others
