Question about Mitsubishi VS-6055 60" Rear Projection Television
Tv shuts itself down
The tv keeps turning itself off, and then the remote does not work to turn it back on you have to push the button on the tv itself. after you push the button on the tv, the remote works again until it shuts itself down again. you have to keep turning the tv back on for about half an hour or so and then it finally will stay on. what do you think the problem is.
  • Mitsubishi Master
  • 3,866 Answers
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 25, 2009
  • MEHMET
    MEHMET Mar 11, 2018
    Sharp smart tv shut down by itself after 5 minutes if it rest a long time. Then shut down after some seconds.
    Tv used to shut down by itself after 30min when I bought it as used and i opened big holes on tv cover on behind. then the time delayed up to 3 hours.
    But now it shut down after 2 seconds if tv rest 10 hours the time is initially 5 min then 1-5 seconds.
    I changed 7 pieces capacitors but nothing changed. The power card number is HLL-4255WJ
    And it has 12v and 16v output, 12v is always constant. On 16v output, there is 19v when tv standby, when the tv is working it drop to 17volt.
    What is the problem?
2 Suggested Answers
6ya staff
SOURCE:
ArcAiN6
Chris May
  • 152 Answers
SOURCE: My TV shuts itself down by itself
Agreed, one of the problems is power supply problems, also, overheat protection may also be the cause, make sure the internals are dust free, compressed air works wonders, remove the back cover, blow as much of the dust as you can off of the componants, replace the cover, and see what happens...
NOTE: If you are using a home / shop air compressor, make sure to have a vapor filter to remove any moisture from the air lines. water + electronics = BAD
Posted on May 29, 2009
Need remote code for Vizio D32h-CO. No remote for TV. Have Dish remote
For my universal remote control's manual, all of the VIZIO codes are:
11758
13758
12757
Also, remember that you can have the remote scan for codes on its own. On the remote just hold the "TV" control button (should be at the top near the power button) and the power button turns on. Then hold the power button too, and it shuts back off; keep holding until it turns back on and then it will stay on. Then, point the remote at the TV (it should be on) and press the power button every three seconds. It will test a code every two or three seconds. When your TV finally shuts itself off in response, you've got the right code and the remote should work.
Jan 18, 2018 | Vizio Televison & Video
Need to program samsung tv universal remote. How do I do it?
For my universal remote control's manual, all of the Samsung codes are:
12051
10178
Jan 18, 2018 | Samsung Televison & Video
There is shadows on the insdide of the screen
Turn your TV on by pushing either the power button on the front of the TV or the power button on the remote control, which is located in the upper right corner of the remote.
Step 2
Press and hold the "up arrow" button on the remote control. The up arrow button is located in the middle of the remote, to the left of the "Input" button and below the "Picture" button.
Step 3
Press the power button on the TV while still holding down the up arrow button. The TV will turn off and then turn itself back on.
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV to its factory settings.
Hope this helpout.......
Aug 03, 2010 | Televison & Video
How do i reboot my konka television?
Step 2
Step 3
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV its factory settings.
Aug 03, 2010 | Konka KDL32AT23U 32 in. LCD Television
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
UNIT TURNS ON AND RIGHT BACK OFF, KEEPS CYCLING LIKE THIS
I had the exact same problem. Googled and fond someone had gotten the tv to stay on by hitting "enter" on the remote as soon as they saw "AKAI" logo onscreen. That didn't work for me, but it got me holding other buttons down on the remote, all tried no go. So I then decided to tinker with buttons on the tv itself and VOILA! If I hold down the MENU button on the tv, the damn thing works perfectly! Every function still works from the remote too. So I taped the MENU button ON THE TV down, and all is well. After having the tv sit for 6 months, tripping over it during a move... now I have it back and no repair bill. Hope it works for you guys.
No charge... ;)
Jan 28, 2009 | Akai PDP4225M 42 in. Plasma Television
Remote control
buy the radio shack "6 in 1" remote. It is absoluetly amazing. picked up all my codes, and actually uses voice commands to step you thru the process. It is the only remote I could find without spending 100 bucks or more that worked for my sylvania, and at only 15 bucko's, you can't beat it.
Dec 21, 2007 | Sylvania LC320SS8 32 in. LCD Television
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Mar 29, 2006 | Apex Digital PF2025 20" TV
Televison & Video Logo
638 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
