I have a Viper 5704 alarm/ remote start system I'm installing on a manual tranny 2005 Chevrolet Colorado. When I try to initiate the remote start sequence before exiting the vehicle, I keep getting the 5 flashes of the park lights indicating the brake wire is active. Only problem is it's not. I relay isolated it just to be sure there isn't some trickle current, and tested that my relay operates only when the brake is pressed. it works as it should, but I continue to get this fault. The tach wire is connected are learned correctly, the neutral safety wire is connected to the emergency brake, the bake switch is not defective, there are no burnt out bulbs in the tail lights, and because of the relay there can't be any trickle current causing a faulty signal. If there was, the current would be obvious and measurable. Do I need anything other than the remote start module and bypass module for manual tranny vehicles? Something to bypass the clutch or something? I have no idea what can be causing this fault. Any help would be greatly appreciated! Bryan
SOURCE: driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
SOURCE: '98 Audi A4, Viper 5501. Car auto-starts and runs
You will be best to connect the real tach wire. You will need to programme the alarm to recognise the speed of the engine, this way it will know where the idle position is.
SOURCE: Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
SOURCE: Viper Two-Way Remote
I had the exact same problem. Disconnect your vehicle battery for 30 minutes. That fixed it for me.
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
