Question about Samsung Prostar 816 Phone
Some of the buttons don't work and the Hold function doesn't work
Can a Samsung Prostar 816 phone be replaced by a twelve button model?
  • Cris Graue
    Cris Graue May 11, 2010
    My main system the Prostar 56ex/120mx can use keyset 816 and 824. What is your system NOT YOUR handset model?
    Novelist:
  • 201 Answers
The Prostar 816 phone system can only use Prostar 816 phones. There is a rare larger Prostar system that can use other Prostar phones along with the 816 but typically was only installed in situations where more than 16 phones were needed. If you are looking at non-prostar phones like the Samsung DCS 12 then they certainly will not work.
Posted on Oct 21, 2007
SOURCE:
Trying to make a conference call from the conf speaker (using the flash button) calling two outside lines.
Once you start using the Conference key on the Prostar 816 you will find it really easy to use, and very helpful! I have uploaded a training video for you to watch, other prostar 816 clips are available on Youtube searching for abbeytel. Visit www.abbeytelcom.com for written copies.
Nov 22, 2010 | Samsung Prostar 816 Phone
Are there any models of the prostar that support caller id?
No. The Prostar 816 is a 1994ish analog system. It was replaced with the DCS digital systems and they do support CID. The phones are not interchangeable.
Carl
Sep 22, 2009 | Samsung Prostar 816 Phone
How do I turn off ringer for fax line on prostar 816?
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line button for the fax line
4) press the button for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
Jul 16, 2009 | Samsung Prostar 816 Phone
CHANGE SPEED DIALS ON SAMSUNG 816
with the handset on hook dial #06 the display should read MMC DISABLED enter 4321 then 1, press # to enter Press ALM/SD button, dial the 2 digit code 10-98, dial the phone number you want stored ( pressing hold inserts a 3 sec. pause and msg inserts a hookflash) press the ALM/SD button to store the number. repeat the procedure for additional speed dial programming.
Jul 08, 2009 | Samsung Prostar 816 Phone
Prostar 816
with the handset on hook dial #06 the display should read MMC DISABLED enter 4321 then 1, press # to enterpress ALM/SD button, dial the 2 digit code 10-98, dial the phone number you want stored ( pressing hold inserts a 3 sec. pause and msg inserts a hookflash) press the ALM/SD button to store the number. repeat the procedure for additional speed dial programming.
hope that helps
Mar 20, 2009 | Samsung Prostar 816 Phone
Need manual
The way to tell if you have either an 816 or an 824 is by the ammount of dss buttons on the left side by the handset. If there are 16 then its an 816, if there are 24 then its an 824. It should also be on the label on the bottom of the phone if its still there. hope that helps.
Feb 04, 2009 | Samsung Prostar 824 Keyset Telephone
Can't find code to add transfer to soft keys on prostar 816
Transfering on a Prostar 816 is done by using the DSS buttons on the right hand side of the phone. This is accomplished by having your outside call in progress and pressing the DSS button of the persons extension you wish to transfer it to. If you want to screen the call wait for the extension to answer otherwise hang up and the call will be transfered. Transfer keys were only placed on the 800 series sets and was a non movible button.
hope that helps
Jan 22, 2009 | Samsung Prostar 816 Phone
Samsung Prostar 816
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
Aug 30, 2008 | Samsung Prostar 816 Phone
Prostar 816 On-hold ring-back feature
You can stop the recall function on any indidual call by double pressing the hold key to invoke exclusive hold. Watch this clip or see many more at www.AbbeyTelecom.com
Oct 18, 2006 | Samsung Prostar 816 Phone
Lands Phones Logo
334 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Maher Kareem
Level 1 Expert
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
