Apple Ipod  Nano Second Gen. Green (4 GB) MA487LLA MP3 Player Logo
A
Anonymous Posted on Jan 08, 2014
Compter does not recognize my ipod shuffle - Apple Ipod Nano Second Gen. Green (4 GB) MA487LLA MP3 Player
5 Related Answers
A
Anonymous
  • Posted on Dec 27, 2007
SOURCE: ipod shuffle will not work
take the ipod back and buy a sony, ipod suck I have been waiting on the "ipod help line" for 30 mins on my mobile.
My ipod shiffle won't work at all!!
Anonymous
  • 342 Answers
  • Posted on Apr 27, 2009
SOURCE: Ipod shuffle not recognized
Usually the solid orange light means it is charging but no connected to itunes. Let it charge for a while then try the reset. If none of this works, take the ipod back to the retailer where you bought it and exchange it for a different one. If the second ipod does the same thing, you most likely have a USB issue. For that you will either need to update the drivers or other software. Possibly even need a new USB card all together. If possible try a known working ipod with your computer. If that ipod loads fine, it is the ipod shuffle for sure.
Anonymous
  • 828 Answers
  • Posted on Jul 21, 2009
SOURCE: My computer does not recognize my ipod shuffle when I plug it in?
connect the USB Connector properly and install Itunes to recognized your IPOD connected itself.
here is the link to download new itunes www.apple.com
Anonymous
  • 23 Answers
  • Posted on Oct 24, 2009
SOURCE: Computer won't recognize 2 gen ipod shuffle. Can't
Can it charge if you plug it into the usb charger in the wall?
If it can, that means that the inside of the shuffle is ok because it's still making a connection and charging. If not, you'll need to start replacing parts. If it charges, keep reading.
I'll assume your on Windows, so right-click My Computer > Properties > Hardware > Device Manager. Find your iPod (it will be under drives or something like that) right-click it and Uninstall.
Then go to Action (I think) > Scan for new devices and it will re-discover the iPod, and re-load the drivers for it.
Anonymous
  • 10 Answers
  • Posted on Jan 29, 2010
SOURCE: When I pulg in my Ipod shuffle Itunes recognizes
it could be your flash memory is corrupt or that you need to reformat and re-install the latest ipod/itunes software. if you continue having problems you should contact your local apple store they should be able to figure out the problem.
How do I get the computer to recognize the iPod shuffle?
Go to iTunes site and download iTunes then install to your computer then try to connect your ipod shuffle
http://www.apple.com/asia/itunes/
1helpful
2answers
download the ipod reset utility
it will rest your ipod to original settings just follow the instruction after you finish the installation
after that open your itunes and it will be recognize
note: there must be no itunes open / media players eg vlc player etc
Ipod shuffle flashes orange light and dosen't show in itunes
if you have itunes loaded already on your pc then try plugging the ipod into a different usb port to the one you have already tried. Hopefully it will be picked up.
IPod shuffle 1st gen. Not Recognized By PC
Try a different USB port first. Here are some other suggestions:
Connect iPod shuffle to a high-power USB port on your computer. iPod shuffle may
need to be recharged.
â Make sure you have installed the latest iTunes software from
www.apple.com/ipod/start.
â Try connecting to a different USB port on your computer. Make sure iPod shuffle is
firmly seated in the dock. Make sure the USB connector is oriented correctly. It can be
inserted only one way.
â iPod shuffle might need to be reset. Turn iPod shuffle off, wait five seconds, and then
turn it back on again.
â If there is no status light (or the status light is dimmed) and iPod shuffle doesn’t
appear in iTunes or the Finder, the battery may be completely discharged. Let
iPod shuffle charge for several minutes to see if it comes back to life.
â Make sure you have the required computer and software. See “If you want to doublecheck
the system requirements” on page 25.
â Try restarting your computer.
â If none of the previous suggestions solves the problem, you might need to restore
iPod software. See “Updating and Restoring iPod shuffle Software” on page 26.
â If restoring iPod shuffle doesn’t solve the problem, iPod shuffle may need to be
repaired. You can arrange for service on the iPod shuffle Service & Support website at
www.apple.com/support/ipodshuffle/service.
2answers
IPOD SHUFFLE NOT RECOGNIZED
Maybe it's because that the USB isn't clean enough. Try cleaning it.
Ipod shuffle will not work
IPOD Shuffle (the tiny silver one) won't charge
Is the IPod able to be recognized on the computer? If not, you could try the 5 R's,
Reset
Retry
Restart
Reinstall
Restore
You could also try to restore the ipod back to factory defaults and see if that would help
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
