Question about York Fitness York R101 Rowing Machine
Adjusting redistance The resistance knob is just turning but it doesn't seem to be going anywhere. Certainly doesn't seem like it's adjusting the resistance.
I hav an edge 426 magnetic bike an there is no resistance/tension. how do i correct this?
Hi There, does this machine adjust resistance with a turn knob or via electronic buttons? If it's a crank or turn style resistance adjustment, this is usually positioning a pair of magnets near a spinning disk inside that front cover. Electrical "magnetic" resistance units use an Eddy-Current brake system which also produces a magnetic field near the spinning disk, either way the magnetic attraction properties will stop any metal (conductive) disk from spinning, or at least provide a resistance to it spinning ;o) Crank tension units have a cable and pulley system inside. Good Luck
Mar 08, 2016 | Exercise & Fitness
I have a bike that there is no resistance when paddling.
if this is a stationary bike, look on the wheel for a hand operated knob that has a roller on the tire itself.. this is a tensioner..it will need tightened up..the tighter you go the more resistance you get.the new ones use electronic braking system..dont now how it adjusts except by the control module..
Jul 31, 2014 | FreeMotion Upright Bike C7.7 Battery Pack...
Why doesn't my double burner work?
i wouldnt be surprised if its not the resistance for the lower temperature ,now as to if its in the knob or a electronic controlled resistance i would have no idea ,its not the element i wouldnt have thought as it should have a resistance but yes its possible the element has two windings in it best thing to do is to ask in the spares shop as they will know straight away
Jan 19, 2012 | Kitchen Ranges
Sharp AF-M808X air conditioner. suddenly there is only fan air movement. there is no longer any cooling; turning the thermostat knob to a higher level doesn't "kick in" the coolant. but...
Simple test: the thermostat in your unit is electromechanical - unplug the unit from the mains, take it out and measure the resistance between the 2 electrical contacts, if it doesn't goes to near 0 when you turn it even a little bit then it's defective and it will have to be replaced.
If the resistance does indeed goes to near 0 then the defect is in the AC system. Another simple test: open the casing of the unit and put your hand directly on the compressor; now turn the thermostat button. If it doesn't vibrate then the starting capacitor of the compressor has failed and it will have to be replaced with a similar one.If it vibrates then the cooling circuit has got a leak and all the fluid has been lost. For that you will have to call a pro that will solder the leak shut and refill the circuit with the appropriate fluid - only he will have it, it's not sold on the customer market.
Jul 22, 2011 | Sharp AF-M808X Air Conditioner
The resistance belt on my nordictrack 1300 woulnt tighten. How do I fix it? Thanks for you assistance.
When using the NordicTrack in manualmode, you can adjust its resistance by twisting a resistance knob, locatedeither in the corner of the console or on the upright support. If the treadmillbelt slips from side to side, you need to adjust its tension via bolts locatedin the back of the machine frame. First find the treadmill adjustmentbolts in the rear end of the treadmill frame, to either side of the belt. Now putin an Allen wrench into each bolt, one at a time, and turn each bolt aquarter-turn clockwise. Slip one hand among the belt and the treadmill deck. Ifthis doesn't pull the treadmill belt taut, it's still too loose. Tighten thebolts another quarter-turn. Continue testing the belt tension, then adjustingthe bolts as needed, until the belt is just loose enough for you to slip yourhand between it and the deck with no extra slack. Step onto the treadmill andwalk. The belt shouldn't bind or slip side to side. If it does, dismount andre-adjust the bolts until the belt tracks correctly. AV
Jun 11, 2011 | Exercise & Fitness
I have a spinnersport spin bike and as soon as I turn the resistence knob more than two or three times the wheel completely stops and the pedals are locked like I pushed down to stop the bike. I have...
The adjustment maybe in pad mechanism and not the knob. Observe the pad movement while turning the knob usually their is a cable tension adjustment on the pad arm.
May 12, 2010 | Cycling
Broken adjustment knob on Zone VI 4x5 Field Camera
Any decent amateur engineer or professional engineering workshop should be able to turn a functional replacement for you quite cheaply and certainly quicker than you could order a spare part.
If you want the knob to look totally original then you'll have to pay a little more, but from what I've seen (from photos on the Luminous Landscape forum) it's very easy to fabricate an identical one if you provide the broken parts (or better still an unbroken one from another part of the camera) as a pattern to work from.
Jul 07, 2009 | Wista Photography
Low flame
This problem most likely is with your regulator. if you decide to replace it please make sure you get the right size replacement. Some salespeople dont know the difference there are four common sizes from class 1 to class 4. If you take the old one with you make sure you match the numbers up with a new one.
Hope this helps You
please rate me.
Jul 18, 2008 | Weber Gas Go-Anywhere Grill
GT400 CD DECK
Press and hold the volume knob to get into the setup menu. Press and release the knob repeatedly until you see "Clock Adj". Push the DISP button, then turn the volume knob to adjust the hours. Push DISP again then turn the knob to adjust minutes. When you're done, press the volume knob again. You can download an owner's manual here: http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXGT400®ion_id=1
May 26, 2007 | Sony CDX-GT400 CD Player
York Fitness York R101 Rowing Machine Logo
32 people viewed this question
Top York Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
ray gallant
Are you a York Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
