Question about Roland GX-300 CAMM-1 Pro Vinyl Cutter
Error 02 h6fw
I loading my cuter,than it sees bad position and the cuter heard stop on the lift side.what is this mean? Pleas tall me.thank you
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Reprogram your position..
Posted on Jan 08, 2014
SOURCE:
Passenger Side Windshield Wiper Broken
Hi Jill,
The first thing to check is a 13mm nut that holds the wiper arm in place.See if you can move the wiper arm freely back and forth.There is a nut at the base of that wiper arm,Lift up a cover that is hiding the nut. If it comes loose from being froze from ice or snow. Put the wiper in its rest position and tighten the nut back up.
Feb 06, 2014 | 2004 Chevrolet Cavalier
C956i Precor is displaying Error code 44 ?
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
May 30, 2012 | Precor C956i Treadmills with HR /...
I have a elliptical 546 i that show me error code 42, ramp goes up but no down, what should i do Thank for your help Byron
Lift Position Value Out of Range Precor Error 42
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Feb 16, 2011 | Precor EFX 546i Elliptical Version 4
I have a C956 treadmill. I am getting error code 44, can you tell me what that means?
Corrective Action
Jan 04, 2011 | Precor C956 Treadmill with Cardio Theater...
Received err 42 on my Precor EFX 5.21s - what does it mean?
Model: All Models
Recommended Action:
Dec 28, 2010 | Precor EFX 546i Elliptical Version 4
PLEASE HELP ME WITH CODE 0910
C0910 service code means that your tray 2 is not lifting the paper properly. Most often this is caused by the tray being loaded improperly. So to try and fix this I would open tray 2 and check the loading of the paper and correct if necessary. Reset the code by turning off then on the main power from the back left side of the machine. Leave tray 2 open until the copier warms up and says ready. Then close tray 2 and wait to see if the code comes back. If it does then you have a motor lift problem or the sensor that detects the lift is bad. You can always leave tray 2 open and inch or 2 so that you can still use the copier as this will keep the code from coming on.
Good Luck and Thank You for using Fixya.
Sep 13, 2010 | Minolta DiALTA DI2510F All-In-One Laser...
Windows on Rear Driver side and Rear Passenger side stopped working
sounds like you have a bad swith in the drivers side handle pull out switch board and check for power on those only when turning in down and on position should see power if not bad switch never heard of two motors going bad at the same time
Jul 16, 2010 | 2001 Dodge Durango
I have a problem with my cannon irc 2620n , just show me this error code E220, i guees is same happen with scan lamp , but i wonna know , wat willi mean , en how can i kan fix up, pleas help me i willi...
Does your "lamp" is turned on when you open the cover? If not it could be that you have bad lamp controller pcb.
Try to manually pull the lamp on right side, and then turn on the copier, if lamp assy is moved in left position withaut error, that means that position sensor is OK, and you need to focuse yourself on "lamp"/ LED
Sep 29, 2009 | Canon IMAGERUNNER 2230 Copier
Roland GX-300 CAMM-1 Pro Vinyl Cutter Logo
126 people viewed this question
Top Roland Office Equipment & Supplies Experts
JonSnell Electronic
JonSnell Electronic
Ravi
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
