On most mowers there is a plug (approx. 10mm) under the deck of the mower that must be removed to drain the oil. However I am not familiar with Mountfield. (I'm in US.)
You may be able to contact Mountfield directly to see if you can obtain a manual for the mower. Here is the site with a phone # and an email form:
http://www.mountfield-online.co.uk/conta...On most mowers there is a plug (approx. 10mm) under the deck of the mower that must be removed to drain the oil. However I am not familiar with Mountfield. (I'm in US.)
The easiest way would be to purchase a manually pump up oil change device that draws a vacuum and you put the tube from that device in the oil fill hole and draw it out to its own container
I poured 5 gallons of mixed gas in my Buick car so I asked my mechanic what I should do. His advice to me was to fill the car's gas tank right up so the mixture is not very heavy He said you may see some smoke more than usual but that will not hurt.
While I am not familiar with this brand, typically, in a four cycle lawn mower engine, there will be a oil drain plug in the bottom of the engine or on the lower part of the engine above the deck.
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
