Fp code
SOURCE: Unit shows a code fp.
CODE= FP
STATUS = Freeze Protection Engaged. The room temperature measured by the wirelessremote thermostat or indoor ambient thermistor active sensor falls below 40°F.
SUGGESTED ACTION = No Action required. This setting will disengage when theroom temperature rises above 43°F
Is sit helpful?
SOURCE: its 15 degrees outside and my amana unit is off.
fp means freeze protection.it comes on by it self so pipes in th house dont freeze.and if it only blows cold air one of the heat protectors is probaly bad
SOURCE: Unit Won't Cool Or Heat Just Blows Air and Displays FP
fp means freeze protection when gets too cold out unit comes on by itself so pipes dont freeze
SOURCE: What does the code F1 & F6 mean for the Amana
These codes signify black (F1) or yellow (F6) thermistor problems. May need replaced.
