After replacing the maintenance kit, I get a paper jam error but there is no paper jam
SOURCE: Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
SOURCE: paper jam leading to error code sc440-01
I think the code is a black pcu motor lock. Replacing the black pcu might fix it, but the black waste toner section could be backed up.
SOURCE: paper jam indication, but cannot find the paper that is jammed
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
SOURCE: Maintenance Kit Replaced on Ricoh Aficio AP610N-Now Won't Work
If you cycle power does it try to feed then "jam"? This would be a misfeed, if "the internal parts are shot" could this be the ITB belt got damaged? All the main components of this model are supplies so repair isnt impossible. -Carl
