Using the printer as a fax only. Received a fax but when I sent a test fax either from the feeder or from the scan bed it starts dialing the number and shuts down with a notice of power failure. Turn off and then turn on your printer it says. Did this many times ..still no send fax
SOURCE: SCAN,COPY,FAX PROBLEM
Issue
An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Here is a manual if you dont already have one.
http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
SOURCE: HP 7140xi scanner failure error
Please click on the web link given below and perform the steps as given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00787271&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
For further information contact HP chat support, its free of cost.
CLick on the web link to chat with HP technician.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
SOURCE: hp officejet 7410 fax failure
Had the same problem as everyone else here - would copy fine but faxing or scanning resulted in the "whizzzzzz" sound (with or without the sheet feeder) and a mandatory reboot.
I followed the suggestion of moving the scanner head to a different part of the drive belt and it works fine now (at least until that part of the belt wears down!). Here was the procedure - it took about 10 minutes.
SOURCE: HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
SOURCE: SENDING A FAX TO MULTIPLE RECIPIENTS AT ONE TIME
Type in the first fax number, then hit the Enter key (the check mark), then type in the next number, hit the Enter key, and so on until you've gotten all of your numbers entered. Then hit Start Fax.
