HP Compaq Presario C306US Notebook Logo
Posted on May 25, 2009
I have a Compaq Presario c306 us. I wiped the HD and am installing XP Professional on it. However, during the setup it reports that there is no HD, and it goes no further. I've wiped and reloaded dozens of machines and have never encountered this. I don't think it's in need of a SCSI or a RAID driver, and even if it does, the machine doesn't have a floppy drive. Please help!
  • argyle399 May 26, 2009
    It's a SATA. I always had assumed it was an IDE. I guess I need to get a USB floppy drive and pull the RAID driver off of HP's website, correct? Thanks.
  • Anonymous May 11, 2010
    Is it a RAID, SCSI, IDE or SATA harddisk?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on May 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
593
Points
5
If you have taken the HDD out, perhaps the Compaq adapter they use with sata drives isn't seated or connecting properly or (as I have done myself) is on backwards
Try taking it out, remove the adapter, place the adapter back on HDD, place HDD back in.. On start up check bios to ensure it detects the HDD
If yes problem solved
If not, try same with known good HDD to establish if IDE controller has 'given up'
  • Anonymous May 26, 2009
    you shouldn't need raid drivers.. BECAUSE you only have 1 Hard Disk Drive.
1helpful
2answers
1helpful
Installing XP SP3 pro on my presario C700
Most likely you have a SATA drive which windows is not detecting. Restart the setup and press F6. You will need to use another system to download the SATA drivers and save to a disk. Then when prompted you can insert the disk. You can also upgrade to XP professional which will almost always recognize the SATA drives. Good Luck.
1helpful
I am not able to install Windows XP on Compaq Presario CQ60-104TU
Recommend removing OLD DOS Operating system First. Then Install Windows XP. XP will NOT upgrade older systems unless it's Windows 98 and Fully Updated. However, can NO Longer do because Microsoft does NOT support any versions other than "2000/ME/XP/Vista".
2helpful
Driver probem
the smbus controller holds the driver for ur audio device so first try to set the smbus controller driver
if it again shows a ? mark in device driver nothing happenns just make a forced installation of ur audio driver
2answers
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
2answers
Installing windows xp
You cannot install Windows XP over WIndows Vista. Microsoft has put a lock on the Vista software and will not allow you to downgrade to a lower software. The only way you can do it is to wipe your hard drive completely clean first with a disk deleting software or with the command "fdisk" at the DOS prompt. However, this is dangerous and I do not recommend it unless you have someone professionally trained to do it. It will wipe everything off of your disk and then you can load Windows XP.
Don't forget to rate his solution with 4 stars before you log out.
Installation problem of windows xp on compaq presario cq60-104tu
its most likely your hard drive is not recognized by xp because it is a SATA drive. You need to go into your BIOS and set the compatibility mode for sata. or if your bios does not have this option then you need to install the drivers when xp asks if you would like to install any third party drivers during setup check with your manufacturer for the required drivers
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
3helpful
5answers
AUDIO DRIVER FOR COMPAQ PRESARIO V6425TU
http://www.zyxware.com/articles/2007/12/13/drivers/compaq-presario-v6425tu-laptop-drivers-for-windows-xp
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
