SOURCE: Thorens TD 126 Mark III - Motor will not run with belt attached
Maybe next time you might turn it OFF before handling the belt.
Try this with power off - manually rotate the turntable and look for where drag might be. You should be able to feel the drag. It is possible you didn't route the belt properly.
SOURCE: Thorens TD 126 MK II Motor Pulley problem
There's either a lot of grease or something in the motor, or the motor control circuit has a fault on it. Try spraying the motor with Servisol Video 40 first. (available from Maplin UK or Radio Shack USA).
