Its likely that the motor has stopped working completely so much so that the load sensor keeps the machine off completely. Likely you will need to get the motor serviced or replaced to get the norditrack running again.
HI Michelle,
Sorry to say this,please call authorize service agent.
regards,
nuwan
SOURCE: When we are using are Nordictrack A2105 for about
From what I am reading the console also goes blank. If this is correct it very well might be a loose connection especially with it being incosistant with the duration of time between shut downs. The lubrication could be the issue but normally it will not cause the console to shut off also. It will normally only cause the thermal switch in the drive motor to shut down until it cools down to approx. 115 f then it will start back up. But with the time frame being so short if the user is around 275 to 300 pounds this could be a cause where the lubrication would be a greater issue.
Good luck.
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: NordicTrack Exp 1000...stops after 40-55 minutes
My EXP000 is doing the same thing. But it is doing it when it is cold also.
http://sites.google.com/site/antiquebriggsandstratton/
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
SOURCE: I have a NordicTrack A2250, about 2 years old.
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
