Sony Bravia Z KDL40Z4100 TV Logo
Posted on May 25, 2009
Sony KDL-40WL140 vs KDL-40Z4100
I have narrowed down my choice for new TV to the Sony KDL-40WL140 or the KDL40Z4100.  The KDL40Z4100 is $100 more, is it worth the extra money?  What is the advantages of one TV over the other.
Thanks for any insight you can provide.
Mack
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1336
Points
13
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
Sony Bravia KDL-40Z4100 Led blinks 12 times. No picture or sound
DO NOT replace the power board, it will NOT fix the TV...You have either a bad tcon board or panel, we subscribe to Sony service literature at our shop, also its available online. https://www.manualslib.com/manual/1116311/Sony-Kdl-40z4100-B-Series.html?page=12#manual
My sony bravia 40z4100 picture weird people skin look red or green shiny.the menu looks fine.anything with letters looks fine,
Check and replace the T'Con board. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Distorted Colors on Sony Bravia KDL-40Z4100
T'Con board fault. For most Sony sets; T'Con is an integral part of the panel. It will be best to contact the authorized service center for Sony in this case. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faces looking strange on sony kdl-40z4100
T'Con board suspected. Contact the authorized service center for Sony.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SONY KDL-40Z4100 COLOR BLEEDING
The main digital board should be checked. It might need replacement. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
1helpful
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Lcd screen
You will have to have the factory service replace the screen. This is a very involved job. The replacement screen is available from the Sony parts department if your set model is not obsolete yet.
From experience you will find it cheaper to buy a new TV set than replace the screen!
Jerry G.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
