It is not going down to minuse 10 degree. please help. it has ice on the out side coil.
The defrost system has failed and is not de-icing the coil or, the door is not sealing tight or too much time open allowing excess humidity to enter the chamber, thereby overcoming the capabilities of the defrost system. The system has a defrost timer someplace, check to see if it is running. If not, you can probably advance it into a defrost cycle with a screwdriver. (turn the shaft slowly until a click is heard and the system stops) Allow 20 or 30 minutes for the coils to defrost, and restart with the screwdriver if it has not took off on it's own. If the timer is found not running, replace it.
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
