Key wont turn the ignition and steering wheel also is locked,please help me to unlock ignition. do not know what to do.
SOURCE: ignition
See Procedure for REPLACEMENT.
1.
Disconnect the negative (-) battery terminal.
2.
Remove the crash pad side cover (A).
3.
Remove the ignition switch (A) after loosening the screw and disconnecting the 6P connector.
4.
Remove the steering column shaft (Refer to the ST group).
5.
Remove the key warning switch and key illumination lamp (A) after loosening the screws and disconnecting the 6P connector.
6.
If it is necessary to remove the key lock cylinder (A), Remove the key lock cylinder (A) after pushing lock pin (B) with key ON.
7.
Installation is the reverse of removal procedure
SOURCE: key wont turn in ignition
had the same problem with a 99 dodge van. tow truck driver put the key into the ignition and tapped it a couple of times while turning the key to freed it up and start the engine. works as long as you leave the key in the ignition so i use a second key to lock/unlock the van. hope this works for you. gary
SOURCE: The key wont turn in the ignition of my hyundai
hi from uk please try this ? with key removed try gently turning steerwheel to the right if you feel a slight spring in steering ? hold on the spring and insert key it should work and release lockand turn ign on ? if steering is springing on left ? try as above the same method not unusual for steer lock to prevent turning key as the steering even in straight position ? the necessity to gently release load on lock is req'd to allow key to turn/unlock the steering lock from the steering column practice doing the above each time you fit key to unlock steering and tuning ign on to start hope this helps
SOURCE: The ignition to my Hyundai Tucson is in locked...
check your key see if its not damaged ok also press the break move the steering wheel slowly and move the key as you are moveing the steering wheel
SOURCE: Unlocking the steering wheel
You'll need to have it diagnosed. Without actually looking at it myself, there are numerous possible causes and to take you through each one would take days.
