SOURCE: I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel
sound from just one speaker. Simply hook up both the left and the right
channels to the special terminals on the speaker. Hook up one channel
only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
SOURCE: JAMO SUB 650
The jamo sub is a fine buy but also look at subs from REL as they can hit hard when needed and are great for music.Now on to your amp,look round the back and you should find a socket marked sub pre out,plug a sub or phono lead into this and then into the input on the sub,this could be marked in or line in,turn up the volume or gain on the sub and also make sure you have the sub turned on in the speaker settings in your amp.
Hope this helps.
Cable guy.
SOURCE: sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
SOURCE: Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
SOURCE: i want jamo sub 1810 circut diagram
Check out this link:
http://2getdtv.com/directv/stereo_receiver_codes.html?phpMyAdmin=ed9585cdc5a4551847999cb4dbcce76a
