When you click 'print' on your computer, change the printer-settings to "double-sided" or "print on both sides", and then click OK. The printer will do the rest.
HP Deskjet F380 falls under the F300 all in one series of HP Printers.
You need to contact your nearest HP dealer to buy a PSU for your printer. Or else contact HP Technical Support over phone for more info.
Most hp deskjet printers are not enabled for double-sided printing. This feature is common with laserjet printers. So if you are using a deskjet, please you may to manually print your double sided.
If your printer is a laser jet you will find the selection under your print menu. Press ctrl P (keyboard) and the print menu appears. Click on each tab to see which one is contains the double-sided selection button. select it and print. The tab should be titled "Basic" depending on the your printer.
If your printer is a deskjet, go through this procedure to see if your model is enabled for double-sided printing and enable it.
Goto Start > Printers and Faxes.
See whether your printer is set as the default printer. (Default printer icon has a tick mark next to it).
Double-click the printer icon.
You will see a list of documents pending.
Delete all the files. (Or select an item, and from document menu, click cancel. Do this for all the items).
Close this window.
Right-click the printer icon and see whether 'Pause printing' is ticked. If so, click it to remove the tick mark.
Restart the printer and the computer. (This is optional, but better to do it).
Now it will be OK.
go to control panel click on printer and fax double click on your hp printer there you can delete your pending print its take a time if not restart your computer and unplug u r printer then conect your printer
I have provided all the web link in a single web site, which ever you feel good please click on the web link and perform the steps as given in the web page.
> start-->run, type services.msc
> double click on print spooler and click on stop and then click on start. press ok and close all the windows.
> unplug the usb cable from the printer
> now go to control panel and open printers and faxes.
> right click and delete all the printer icons related to hp deskjet f300 series.
> now plug the usb cable back to the printer
> wait for few minutes while it installs the driver automatically.
> thats it... now try printing
