Casio FX991MS Scientific Calculator Logo
j
jilpat Posted on Jan 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to find 3inverse%11
To find the remainder of an inverse number by a natural number
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Jan 07, 2014
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4674946
Points
21596
I am afraid the question does not make complete sense.
However to find the remainder of an integer division
You use the fraction [a b/c] key
Example remainder of 29 divided by 15
29 [a b/c] 25 [=]
That gives you 29/15
Press [SHIFT][a b/c] (d/c), you get 1 u 14 u 15 or 1 14/15. The numerator of the fraction part is the remainder.
  • k24674 Jan 07, 2014
    Sorry. 29 [a b/c] 25 [=] should be 29 [a b/c] 15 [=]
Iverse of ln
To calculate the natural antilogarithm (inverse logarithm ) of a number, press SHIFT [e^x] then enter the number and press =
The e^x function is the shifted function of the ln key.
For example, to calculate the inverse logarithm of 3, press SHIFT ln 3 =
1helpful
Inverse of ln
2helpful
2answers
Im pressing the buttom that everyone is saying is the inverse key but it is saying error. i really need help with this.
It is much more enlightning to tell us what you want to do rather than talk about something that does not exist. And one thing that does not mean anything is that ellusive INVERSE key that everyone and his dog is looking for.
The additive inverse of a number a is its opposite (-a). The key to use is the change key (-).
The multiplicative inverse of non-zero number a is its reciprocal 1/a
The inverse of the natural log (LN) function is the EXPONENTIAL function e^(x). On most calculators if one function is accessed diectly (the marking is on the key), its inverse is accessed by pressing [SHIF] (Casio, or [2nd] (TI) or [2ndF] (Sharp).
The inverse of the function raise 10 to a power [10^x] is [LOG]
Similarly, the inverse of the sine function SIN is the arcsine [sin^-1]. To access the latter, it you press [2nd][SIN]. The same is true for arcosine [2nd][COS], and arctangent [2nd][TAN]
The inverse of the square functions [x^2] is the square root function [2nd][x^2]
Inverse of x^3 is cubic root
This is just a quick overview.
How to find inverse of log in a casio 991ms calci?
The inverse of the natural logarithm (in base e) is the EXPONENTIAL function (e^x). It shares the same physical key as the LN function. One is accessed directly and the other through the SHIFT key. The inverse of the logarithm in base 10 is the function 10^x. Both functions share the same physical key as described above.
More generally if y=log(in base b) of x =log_b(x) then x=b^(y). The base must of course be a non-zero positive number.
1helpful
What button do you push on the TI-86 calculator to do the inv log function?
For the inverse natural log, press 2nd LN. For the inverse common log, press 2nd LOG.
For example, to calculate the inverse natural log of 2, press 2nd LN 2 ENTER and you'll get about 7.389 .
On the TI-36X, whihc key is the inverse key and
The inverse key is marked "1/x" (second key on the third row). The natural logarithm key is marked "LN" (fourth key on the top row).
1helpful
Using the correct key combination to determine inverse log
Sorry to contradict you but there are many types of logarithms, the most important ones are
  1. the common logarithms (log in base 10),
  2. the natural logarithms (logarithms in base e)
  3. the binary logarithms (logarithms in base 2)
On calculators, the common logarithms are labeled [LOG], and the natural logarithms are labeled [LN].
The inverse function of the natural log function is the exponential (e^(x)), and the inverse of the log in base ten function is the function ten to the power of. It is called (sometimes) the antilog
Ex:
Question What is the antilog of 3.5678?
Answer The antilog of 3.5678 is 10^(3.5678) = 3696.579068
Verification: log(3696.57908) =3.5678
Hope it helps.
9helpful
How do I calculate the inverse log on the TI-89?
The wrong terminology is playing tricks on you.
  1. If you are talking about the natural logarithms, the inverse function of the natural log is the exponential: ln(e^(x))=e^(ln(x)) = x
  2. If you are talking about the common logarithms (log in base 10) to find the antilog of a number, say x, you raise 10 to the power of x.
Exemple: What is the antilog ( that is the name, not inverse log) of 0.345?
Answer; antilog of 0.345 = 10^(0.345) =2.21309471
Look at the last two commands on the screen capture.
Hope it helps
Thanks for using FixYa
How do I enter an inverse log function into my claculator? for instance log-1(-.4/10)
If you want to do correct mathematics you should strive to use the right words to express the concepts, and the right symbols too. While the logarithm function has an inverse function, it is never called an inverse log and it is never represented as log^-1. (I know you are going to protest and claim that the inverse of a sine function is represented on calculators by sin^-1. This a manufacturer shortcut, and we have no power to change that.) HP uses ASIN, ACOS, ATAN. These are still manufacturer shortcuts but they induce fewer errors.
Anyway, the logarithm functions do have inverse functions.
1. Natural loogarithm (ln)
The inverse of the natural log is the exponential.
ln(e^(x))=e^(ln(x)) =x
2. Common logarithm (logarithm in base 10)
The common logarithm has an inverse function, often called the antilogarithm or antilog.
There is an equivalence.
y=log(x) <--> x=10^(y)
From what I undesrtand of your exemple, you are looking for the antilog of the number -0.4/10 (or -0.04.)
-0.04= log(x), what is x?
You use the equivalence above to look for x as follows.
x=10^(-0.04) =0.9120108394.
Use the change sign (-) not the regular MINUS sign.
Take the log of the last result (still stored in Ans memory) and you get the original number.
Hope it helps.
1helpful
How do I do an inverse log function on my HP 33s calculator?
The inverse of the common log is the raise 10 to a power. the inverse of the natural log is the exponential. The log and the antilog share the same key, one is accessed directly the other as a seconf/shifted function. Same thing for the natural log (ln) and the exponential.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
