HP Compaq nx6310 Notebook Logo
Plamen Meramdzhiev Posted on Jan 07, 2014
Bios password password Power on
brajesh
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Jan 08, 2014
brajesh
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
14
Helped
161
Points
Keep CMOS battery opposite side for 20 mint...durin this perieod unplug power adopter and battery both.your BOIS password will be reset.................
How to remove lenovo R61 thinkPad POWERON PASSWORD
THINKPAD BIOS AND POWER ON PASSWORD
The BIOS password is configured from the BIOS setup and this password is stored on an 24RF08 EEPROM chip. There is no backdoor password available and IBM/Lenevo support says the motherboard needs to be replaced. Also removing the BIOS battery to discharge the BIOS and reset it to the default settings will not allow you to bypass this password. This also applies to the Power On Password and the Hard Disk Password. There is a way to crack the password but you need electronic skills, electronic components and several programs plus a working computer to carry out this task. For details on how to do this check this WEB site. http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
tip
REMOVE BIOS AND POWER ON PASSWORD ON THINKPAD LAPTOPS
The BIOS password is configured from the BIOS setup and this password is stored on a 20RF08 EEPROM chip. There is no backdoor password available and IBM/Lenevo support says the motherboard needs to be replaced. Also removing the BIOS battery to discharge the BIOS and reset it to the default settings will not allow you to bypass this password.
For details on how to do this, check out this WEB site.
on Mar 14, 2010 • Computers & Internet
tip
How to Reset BIOS Password?
There are two passwords in BIOS. One is start up password, the other isBIOS setting password. If you have forgotten the start up password thatmeans you cannot open computer at all. Then the first method is theonly thing you can do. Other methods can use to clear setting password.
==①:Motherboard Battery Discharge==
The common way toreset start up password is discharge Motherboard Battery. Most of thecurrent motherboard BIOS is using the button batteries to provideelectric power.That means if there is no electricity, the informationit contains will be lost. When it’s on power again, BIOS will set backto its original state, of course, there will be no BIOS passwords. Butyou will lose your setting at the same time.
What we need to dois to power off computer, open the computer box, and then unplug thepower plug of the computer to make sure that it is no electricity atall. Then locate the white silver button battery on the motherboard.Remove the battery carefully. Perhaps 30 seconds later, put back thebattery.
After put back the computer box then power on, thesystem will prompt “CMOS Checksum Error-Defaults Loaded”. That meansCMOS errors detected during inspections, had been included in thesystem default, BIOS password cracking success!
On somemotherboards, the battery is soldered to the motherboard, making itdifficult to remove. If this is the case, you have another alternative.Somewhere on the motherboard you should find a jumper that will clearthe BIOS password. If you have the motherboard documentation, you willknow where that jumper is. If not, the jumper may be labeled on themotherboard. If you are not fortunate enough for either of these to bethe case, you may be able to guess which jumper is the correct jumper.This jumper is usually standing alone near the battery. If you cannotlocate this jumper, you might short both of the points where thebattery connects to the motherboard.
==② : Backdoor BIOS Password==
Eachmotherboard manufacturer has set a backdoor password in order tofacilitate the provision of technical support. The backdoor password isa BIOS password that works, no matter what the user sets the BIOSpassword to. These passwords are typically used for testing andmaintenance. Manufacturers typically change the backdoor BIOS passwordsfrom time to time.
AMI Backdoor BIOS Passwords
Reported AMIbackdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW,BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords
Onereported Award backdoor BIOS password is eight spaces. Other reportedAward backdoor BIOS passwords include 01322222, 589589, 589721, 595595,598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARDSW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT,CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332,J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz,TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords
ReportedPhoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, andPHOENIX. Backdoor BIOS Passwords from Other Manufacturers Reported BIOSbackdoor passwords for other manufacturers include:
ManufacturerBIOS Password
VOBIS&IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enoxxo11nE
Epox central
Freetech PosterieI
Will iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
SOYO SY_MB
TMC BIGO
ToshibaToshiba
Remember that what you see listed may not be the actual backdoor BIOS password,this BIOS password may simply have the same checksum as the realbackdoor BIOS password. For Award BIOS, this checksum is stored atF000:EC60.
==③: Software Crack==
There are a lotsoftwares to test systems or start up password, but they need to run onWindows. So it is only used to reset BIOS setting password.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
•ACER/IBM BIOS
•AMI BIOS
•AMI WinBIOS 2.5
•Award 4.5x/4.6x/6.0
•Compaq (1992)
•Compaq (New version)
•IBM (PS/2, Activa, Thinkpad)
•Packard Bell
•Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
•Phoenix 4 release 6 (User)
•Gateway Solo - Phoenix 4.0 release 6
•Toshiba
•Zenith AMI
Ifall else fails, you might be going to lose some money for technician.But they will use these same methods, try hard by yourself.
on Dec 30, 2009 • Computers & Internet
I can't reset my bios password
BIOS password can be removed using either of these two ways:
1) Take you BIOS cell out for a while and then plug it in again and your BIOS password shall be removed.
2) You can also change your BIOS Jumper Setting. Generally the BIOS jumper resides on pin 1 and 2. You simple take it out and then plant it in on pin 2 and 3. Power on your computer and then power it off. Then change the jumper to default setting that is pin 1 & 2 and then once you shall power on your laptop the BIOS password shall be removed.
The BIOS jumper resides on the motherboard and there is a marking on it stating "BIOS" which shall help you identify the correct jumper.
Toshiba Laptop Satellite M30-742 Power On Password Reset????
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore...
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
2helpful
5answers
How do i reset the bios password for my lenovo a310?
User passwords:
Power on
BIOS execution can be controlled by a Power On Password. This password is set in the BIOS Configuration screen, accessed by pressing the F1 key after pressing the power on switch to turn on the PC. If the person at the keyboard does not know the Power On Password, then BIOS execution halts.
Hard drive
The hard drive is controlled by the Hard Drive Password. After the Power On Password is entered, the person at the keyboard must be able to enter the Hard Drive Password, otherwise the disk drive will not spin up for use. Like the Power On Password, the Hard Drive Password is set in the BIOS configuration screen.
Administrative passwords:
Each of the two user passwords can be controlled by a Master or administrative password. If the administrative password is not set, then anyone who knows the user password can change it in the BIOS configuration screen. If the administration password is set, then it is impossible to reset the user password unless you know the administrative password. The Supervisor Password is the administrative password for the Power On Password. The Master Hard Drive Password controls the Hard Drive Password.
Password Recovery is a feature of Client Security Solution 6.0. This makes it possible for an end user to recover from the problem of "I forgot my Power On Password or Hard Drive Password."
c.gif fw.gif Client Security Solution
1helpful
3answers
Could you please guide me how to remove bois possword for travel mate5730g
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
Check below for the picture of the HW Password reser gap. The gap that needs to be "shorted" is G77.
6helpful
3answers
Cannot boot laptop because of bios password
Easiest way to wipe clean the Bios password is as follows:
  • Perform a power drain by removing laptop battery pack and/or docking station power supply and hold power button down for 10 seconds
  • Locate the CMOS battery (usually under the smallest panel on the bottom of the laptop)
  • Remove CMOS battery for 20 minutes (20 is arbitrary can wait longer if you wish)
  • Replace CMOS battery and panel
  • Replace battery pack and/or replace to docking station
  • Power up
The Bios password should now be removed and you should be able to boot with no issues. Thank you for using Fixya and please remember to return to rate this answer.
Greg
17helpful
3answers
Ibm thinkpad r51
What is the default password for my R51 Thinkpad by IBM Model # 2888?
2helpful
2answers
I set the power on password on my ibm 600e and now cant turn it off. How do I do that
go to www.ibm.com go to support page, download the service manual of your model first, it will show you how to reset your bios password or remove your bios passord, usually remove the bios password, it is your CMOS battery (look like a calculator battery) unplug it, and put it back on again, your bios password should disappear. make sure remove the battery first.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
