Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator Logo
Posted on May 24, 2009
Volume on the phone/speaker/ring is very low
I'd also like to know how to change the ring tones. Thank you
spiritsoul
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Jan 13, 2010
spiritsoul
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
10379
Points
63
To change volume: Press HandsFree once, and then press DELETE (several times to scroll through loudness levels from 1 to 4. Then, press Handsfree to confirm setting. Press DELETE to exit & view normal screen.
  • dag526 Feb 26, 2011
    i already follow this instructions... it won't work.
    i already try this instructions but still won't work... please help.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1004
Points
5
You can change ring tones by pressing the flash button until you get the ring you want. When you get the ring you want press the set button.
2answers
Ring tone volume low
possible the phone speaker is weak. cant do anything abt it.
2answers
Elderly friend can't hear his phone ring even though the volume is set at Max Volume
Putting the phone on Outdoor may help or when someone rings before you answer, use the Up Key. Cheers..
I am using a new siemens desk telephone. I dont know the model number & they dint give me the manual. I just could not reduce the ring tone volume. Any help on this is highly appreciated. I am...
Just look at the bottom of the phone, you will find ringer tone volume marked with low & high. Put it to low. For the manual, see the bottom-side of the phone to locate the model number & search the Siemens website for the manual.
sonunny
Jun 30, 2011 • Cell Phones
2helpful
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Incomig calls are exremely low volume outgoing calls have normal volume. Is there an adjustment for this
hi
you can increase your sound by increasing the sound in profile settings.there you can find increasing sound for your ring tone.moreover you can set the ring tone that should have increased quality of your sound.then check the sound in call option.mostly samsung phones speakers have low sound quality
thank you
1helpful
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
1helpful
Nokia E 75 -- to change the volume
Hi there
Go to tone settings to check if your ringing volume has been turned off or it is very low.
If the problem persists after this check then the ringer/speaker of your phone is faulty an it should be changed.
Thank you for visiting fixya
It has low ring that i can not hear it ringing
The ring tone volume on the X1 is not very loud you will just have to choose a loud ring tone that will catch your attention. Have you tried putting both the phone and ring tone volume up by pressing the speaker symbol at the to of the screen and putting both sliders up full.
2answers
Low custom (individual) ring volume
This is not a B/B fault, unfortunatley the person who recorded the ringtone has recorded it at a low level, import into a wave/mp3 studio program and alter the recorded levels.
That is if you have tried the following:
Select Speaker Icon on the front screen of your 8100 (top right) press pearl in, scroll down to advanced, select the current profile (this is defaulted to Normal). Scroll to Phone and press pearl in.
Change Volume to High, if it's already on high, try the option above.
Gadget
Top Innovage Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
