Starbucks Saeco Italia Digital Barista Coffee Machine Logo
Demestichas Dimitris Posted on Jan 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
COFFEE COMES OUT TOO FAST - Starbucks Saeco Italia Digital Barista Coffee Machine
Kelley Hopper
Level 2:
  • Expert 67 Answers
  • Posted on Jan 11, 2014
Kelley Hopper
Expert
Level 2:
Answers
67
Questions
0
Helped
33884
Points
172
Try making your coffee a finer grind. The finer the grind of the beans, the slower the water will flow through the beans. Also fresher beans will make the water flow slower due to the moisture and oil content in the beans.
Weak coffee the water appears to go through too fast
first give me your machine modal number.
if machine has bypass system then ,I can think that your spray head tube is blocked.
if water come from bypass then it comes very fast.
thanks
please rate me
The coffee comes through the machine too fast.
It can be 2 problems: 1Too big granulation of grinded coffee(in this case we have cup filled fast and we have yellow and thin cream or traces of it) Adjust the grinding 2 Filter holders filter(where you put grinded coffee is broken) sometimes it brakes at curves and it is hard to see, wash it and inspect it carefully. if it is broken replace
Coffee brewing comes out in a fast steady stream when brewing, coffee doesn't brew properly and comes out weak. taste like unbrewed.
If it comes out in a steady "stream" it sounds like the sprayhead is missing. The sprayhead disperses the water out and evenly over the grounds.
If the sprayhead IS in place then it could be a temperature problem. If the temperature is not hot enough the coffee will not brew correctly.
2answers
OVER FLOW
The Bunn needs Bunn filters because they are thinner and let water through faster. The cheaper filters will overflow. Bunn's claim to fame is fast...this is just part of the fast process.
Krups FNC3 Espresso Machine
If it's only 18 months old surely it will still be under some sort of manufacturers guarantee, you don't bin 18 month old coffeemakers nor should you be paying to fix them. Put the problem back in their lap.
Saeco Incanto
how tight is the coffee packed in the dripper, the flow rate is determine by how tight the coffee is, thats why you always see the barista press the coffee against the disk of the grinder dispenser in a coffee store
I de-scaled the coffee maker. Now the water comes out so fast that the grounds are overflowing the filter. Can I calibrate it myself? How?
It sounds like the sprayhead is missing. It looks like a little shower head and is screwed on where the water comes out.
Top Starbucks Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
