Humidifiers Logo
S
Susan Hallmark Posted on Jan 07, 2014
Need lid for Reli(On humidifier RCM 832N - Kaz Humidifiers
Question for the HWM-450 4 Gallon Humidifier. This is my second unit now and im having the same problems. Why is the plastic of the lid melting? Sometimes tanks melts to front of unit. Also water has...
get a better brand as 2 failures of the same brand indicate design faults
report the matter to the manufacturers engineering department and ask questions as to why the failures occur
2answers
Model RCM-832. On/off switch works, blows air but no moisture seems to come out. I left it on for at least one day and the water level in the tank remained the same.
First check humid-stat setting make sure that the room is not above setting. Second check that float(water level) switch is being made. Hope that helps
Missing gasket for the refill lid
It may quite hard to get original part replacement . Just find part replacement at local market ( EOM)
Anyone know where i can get a replacement tank for the crane duck humidifier without buying it from crane?
I have an elephant humidifier with a broken fan. I just posted the problem, but I doubt there is a solution. I'm sure the tanks are interchangeable from looking at the manual, if you don't mind an elephant (I don't know if the lid is interchangeable). I would hate to throw it out and have one more thing in the landfill. Maybe I could send it to you?
1helpful
Where do i put the vicks in a vicks humidifier
you have to open the lid to the scent pad heater tray. the vicks pads go inside of there. now if you touch them with your hands you need to immediately wash hands after. cause of the fumes will be very strong. then close unit and turn on and it should work properly
1helpful
1helpful
2answers
Drum does not turn
The rubber coupling is slipping. You may have a problem with the gear case; you can get a new one by calling Venta at (888) 333 8218. But it's possible that the rubber coupling is simply not seated properly. Snap the gear box out and make sure the socket is clean. When you put it back make sure that the coupling post is fully inserted in the drive socket. Hope this works for you ... Venta will supply new parts promptly if you decide you need them.
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
3answers
Doesn't run
When a humidifier doesn't run, it generally means it isn't receiving electrical power or the controls have automatically shut it off. 1) Be sure it's plugged in to an outlet that works and that it's turned on. Check the electrical receptacle for power, using a working lamp, appliance, or voltage tester. 2) If the receptacle seems to be dead, check the circuit breaker or fuse that serves the humidifier's circuit. 3) Check the setting on the humidistat. If it's set lower than the room's relative humidity, the humidifier won't go on; in fact, it may take several hours for the humdistat to respond to the room's changing humidity. 4) Be sure the humidifier's reservoir is full of water. 5) Unplug the humidifier unit. 6) Check the power cord. If necessary, repair the cord. 7) Remove the humidifier's cover panel. 8) Remove the humidistat and check it (as shown below). Replace it if necessary. 9) If it still doesn't work, call an appliance repairperson, take the unit into an appliance repair shop, or replace the unit. To check the humidistat, you?ll need a volt-ohm meter. A humidifier?s fan vaporizes the water in the reservoir and blows the water vapor into the house or room. If you need to check the fan, unplug the humidifier, remove the control panel, and lift the lid. Tighten the fan hub with pliers if it is loose; this should take care of rattles. If the fan doesn?t spin easily when you try to move the blades by hand or if it is still noisy, lubricate the motor bearings with oil. To establish whether power is reaching the humidistat when you know there are no problems with the plug or switches, unplug the humidifier, remove the control panel, and lift the lid. Test it with a volt-ohm meter set to the RX1 scale (or to K[omega symbol] or [omega symbol] resistance on a digital meter). Clip the meter to the humidistat terminals. The meter should jump if you turn the humidistat from high to low. If it doesn?t, you?ll need to replace the humidistat or return it to the manufacturer.
Top Kaz Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
