Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
A
Anonymous Posted on Jan 07, 2014
Bunn water has oil in it - Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffee maker, no hot water
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Mar 16, 2013 • Bunn CWTF35
2answers
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
6helpful
2answers
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
2helpful
2answers
Bunn ST15
Bunn's official position is that this brewer must be hooked up to a water line. The problem with using these as a pourover is the evaporation of the water. it doesn't take much of a loss of water to burn out the element in those models.
Bunn pod coffee tea brewer
Visit the Bunn website on the following link: http://bunn.com/retail/service/faq.html You can download manuals, read the FAQ & get telephone support from them. Please update the question & let us know if the information given was useful to you - Good Luck!
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
