How do i do 2 x A4 double sided copies into 2 x A4 double sided copies on the brother MFC J6720DW
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the
flatbed. Look on the left side. You should see a strip of glass, with
the scanner sitting under it. This strip is used when the document feed
is being used. Make sure it is clean. Most common problem is getting a
little whiteout or the sticky residue from scotch tape on this glass,
which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
SOURCE: Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
SOURCE: BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
SOURCE: Printing double sided with MFC-6490CW printer
Hee is you support website See if they have directions(manual ) to download for instructions. I take it that this printer is designed to print double sided else I can tell you the method that works on all printers.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us〈=en∏=mfc6490cw_all
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !!
On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy
scan window OR the laser scan window can get dirty. If the fax scan
window is dirty, you see streaks on outgoing faxes and copies (but NOT
incoming faxes). If the laser scan window is dirty, you see streaks on
all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
