Honda Pressure Washer PSI 3000 Logo
Posted on May 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Honda gx270 pressure washer. water is not coming out strong.
Honda gx270 pressure washer. no water pressure- hose and wand are clear of debris. water not coming out strong like it use to.
  • Anonymous Mar 22, 2014
    No water pressure is coming for my Honda crv 160 pressure washer
Anonymous
Level 3:
  • Master 3,600 Answers
  • Posted on May 24, 2009
Anonymous
Master
Level 3:
Answers
3600
Questions
Helped
1576296
Points
11774
Did you check the inline screen for dirt?
  • Anonymous May 28, 2009
    pull the brass nuts off one at a time allow water to be on slighty without it running watch for trash comming out of ports, do this to all brass plugs, check that wand is turned to allow high pressure if you turn it one way it will have low pressue. Mine has to be pulled out or pushed in for high pressure did you check that? and did you store it with no water in the machine and get ll the water out before winter, did it freeze? and bust the pump?
2answers
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
It starts turns on but water will not come out of nossel???
Many of these devices have strainers on the input (garden hose connection) of the pump. Remove the hose and check and clear debris from strainer. Reconnect hose and turn on supply water. Do NOT start engine / motor. Pop the nozzle from the end of the wand and squeeze water trigger. Hose pressure water (or less) should flow from the wand. Of not, youll have to see if water is leaving the pump by inserting the nozzle (or something that will if it) into the hose connector. If water still does not flow - there is an issue with the pump.
No pressure build up from pump
looks like this is a small triplex pump.ensure the pump is acually turning over with the power unit and the love joy coupler is working properly and there is no stripped out key ways ect. was the hose jumping before the loss in presure? this could indicate a washed out in the intake or dischage valve. or debris hung up there in. check the pressure relief valve/unloader valve for proper function may be the pressurised water stream from the hose is by passing .repair /replace as required.
Devilbis Excell pressure washer with Honda engine runs smoothly without wand, but stalls when wand is attached.
If the pressure unloader is not working correctly and/or the nozzle is partially clogged with debris, the engine will be overtasked. Try lowering the pressure by turning the pressure knob to lowest setting and test. If the engine continues to run, gradually increase the pressure. Try using the washer set to about 75% of rated capacity and use max pressure for stubborn stains. Using any machine at max will shorten the life of components. If lowering pressure does not help, then unloader is faulty or stuck. Try storing the unit with oil in the pump. Remove both hoses and infuse oil into water inlet intill all the water is displaced (let set for day or two). Good luck
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
When garden hose is connected to the pressure washer no water comes out of the wand, engine is off.
Dear radcongirl,
Try removing the high pressure hose from the machine. Then connect the water hose and see if water comes out of the outlet.( you can also try this by putting on the machine for a few seconds). If water comes out of the outlet, then you have a problem in the high pressure hose or the wand and trigger. Check also the lance and nozzel for blockage.
I do not know what kind or model of machine you have, but most machines the water always comes out of the outlet when water is fed to the inlet. In bigger machines this cannot happen because they have a reserve tank.
Regards,
Fulltech.
12helpful
Not getting any pressure at nozzle.
Can anyone Solve this? My simoniz S2500 gas powered pressure washer has low pressure coming right from the outlet. It used to be high pressure until now.. I think it has something to do with the pump and if so, is there anything I can do to repair this problem? The screen is good; water comes out of the hose good, wand is ok......Just that lower pressure is at the wand even at high settings....It comes in a form of a spray in both modes......
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
