Tablets & eReaders Logo
A
Anonymous Posted on Jan 07, 2014
Ipad air will not unlock
Wont slide open to unlock wont turn off
Michael Lei
Level 3:
Master:
  • Apple Master 498 Answers
  • Posted on Jul 18, 2019
Michael Lei
Apple Master
Level 3:
Master:
Answers
498
Questions
0
Helped
122019
Points
1736
Try below steps to unlock your iPad Air.
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
For more methods, check: How to Unlock iPad?
1 Related Answer
beansapimp
bean Hearn
  • 7 Answers
  • Posted on Sep 30, 2015
SOURCE: my ipad is cracked inside it wont slide to let me unlock it
Rotate the tablet so you can use a different part of the screen to unlock it.
My ipad will not slide to unlock or power off
Be sure to check that your battery has enough power to provide this help. Just plug in your charging cable and walk away. Check back in an hours and try powering off or unlocking the screen again.
Hi, I found this on the apple website. Does this help you?
Restart your iPhone, iPad, or iPod touch - Apple Support
https://support.apple.com > en-gb
9 Dec 2015 - Press and hold the Sleep/Wake button until the red slider appears. Drag the slider to turn your device completely off. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
Mac Mini Ipad Locked screen?
Press and hold down the Home button on the front of your iPhone, iPod touch, or iPad while still holding down the On/Off button. Keep holding both buttons as the screen turns off keep holding both buttons until the turns back on again and displays the Apple logo
My ipad is cracked inside it wont slide to let me unlock it
How to unlock ipad 3
As for unlocking iPad, there are several ways you can resort to. Just follow one of them as below shows.
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
How to unlock ipad if I forgot password
If you forgot iPad password, there still are several methods to unlock iPad. Here take one of them as an instance.
iPad Air
iPad mini/iPad pro
Ipad activation required
Turn off ipad
open itunes in your computer
connect ipad to computer
follow instructions in itunes
My iPad air will not unlock
What do you mean it does not slide? Swipe the screen to the left or to the right to unlock.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
