Is there any AT&T near you? i suggest that you go there and have them input the right settings for your mobile phone. And once they said they have done it, try sending a picture to yourself and don't leave AT&T unless you receive your own picture.
DID U CHECK THE SETTINGS MENU
Hi
First you need to go to the my.t-mobile.com website and log in
up at the top-right of the screen (next to support) type in 'Device Configuration' in the 'Ask T-Mobile' box
under 'What is............. configuration/configurator?' Click on the link to use it
select the make and model and get the settings for the t-zones service and the MMS service (follow the simple on-screen instructions) and all done
If still it does not work then do the following:
the APN should be changed to wap.cingular (lowercase)
USERNAME should be WAP.CINGULARGPRS.COM (UPPERCASE)
PASSWORD SHOULD BE CINGULAR1 (UPPERCASE)
THE AUTH TYPE SHOULD BE SECURE THIS IS THE gprs SETTINGS
NOW TO SET UP WAP
the homepage should be: http://device.home/
edit connection type to http the ip address is 066.209.011.032 port number is 8080
edit username to [email protected] (UPPERCASE)
EDIT PASSWORD TO CINGULAR1
ACTIVATE ACCOUNT WHEN DONE
MMS SETUP
go to the MMS settings profile
homepage should be http://mmsc.cingular.com
connection type should be http the ip address is 066.209.011.032 and the port is 8080
username [email protected]
PASSWORD IS CINGULAR1 (UPPERCASE)
THIS SHOULD WORK FOR YOU IF YOU SETUP THE PROFILE CORRECTLY
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Do you have mms service on your phone to send and receive pictures? whats the brand and model of the phone and who is your service provider? have you already called them for the settings?
basically wha you need is mms enabled on your service and then the right settings, aslong as your phone supports mms.
Ill know more when I know the brand and moidel of the phone.,
Thanks
Okay you should be albe to get the settings and the instructions directly from att by calling their customer service number. As far as I know that phone should work perfectly with att
Hi
if you call att customer service they should give you the latest settings that will work perfectly with your phone, have they told you otherwise?
try these
http://forums.wireless.att.com/cng/board...
The settings would be arranged as -
Any further help, let me know.
NOTE: if AT&T MMS is not available, create a new profile by pressing Options>>New.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Wap
Homepage: http://device.home
Service type: WAP
Gateway IP 1: 66.209.11.61
Port 1: 9201
Domain 1:
Service type 2: WAP
Gateway IP 2:
Port 2:0
Domain 2:
DNS 1:
DNS 2:
Timeout: 10min
CSD No 1: +14152441012
User name: 1: [email protected]
Passwrd 1: CINGULAR1
Speed: 1: 9600
Line Type: ISDN
CSD No 2:
User name:
Passwrd 2:
Speed: 9600
Line Type 2: ISDN
GPRS APN: wap.cingular
User Name: [email protected]
Passwrd: CINGULAR1
MMS
Service type: WAP
Port 1: 9201
Domain 1:
Service type 2: WAP
Gateway IP 2:
Port 2:0
Domain 2:
DNS 1:
DNS 2:
Timeout: 10min
CSD No 1:
User name: 1:
Passwrd 1:
Speed: 1: 9600
change these settings in your phone under gprs and mms
Go to the main menu, then select browser settings, profiles
If you don’t have a profile, or you simply want to add a new one, then press Options, Add New (Figure
4). You’ll be prompted for a profile name, choose anything you like –
though I’d recommend naming after the network that you are setting it
up for (e.g. O2 WAP)
You can configure your profile by selecting it in the profile list, pressing the Options softkey, then choosing Settings (.
Set the bearer (which is the method of connecting to the internet) to be GPRS by choosing the bearer, GPRS menus ().
Next, go to the GPRS settings (). Fill in the correct APN (, User ID () and Password for your network.
Finally, back in the profiles menu choose your profile name, press the options softkey and select Activate to make this the one that you’ll be using by default.
To access our Internet Settings page click here
My phoen brand is LG KF 900 and I am using ATT provider
I am using an ATT provider and I wanna know the setting in order to receive and send mms to my LG KF 900 phone.
I need aspecific operation setting for KF 900. I tried both suggestions but it didn't work. I called ATT provider but didn't get the answer I needed because I did not buy this phone from them.
where can I find these GPRS and Wap in KF 900?
are you talking about the model LG KF 900? because there's no GPRS setting in it and in creating a new profile from the browser page it only has title, homepage and internet profile..can't find the rest.
I did check so many times...this phone settings is different from my other LG Prada 850.
everytime I receive picture messages it says "the connection type is wtp" therefore I can't open it. what shall I do?
