Worked in other computer in this Gateway Celeron 1.2gh it does not recognize that it has a cd or dvd in it. Running WinXP Pro with sp2, roxio 9 and Cyberlink PowerDVD6
Something to make my cyberdrive dm166d recognize that it has a cd or dvd in it in a gateway celeron 1.2 desktop pc with winXP PRO sp2.
go to this link http://www.microsoft.com/en-us/download/details.aspx?id=24 download winxp sp3 exe follow instructions disregard for IT professionals and developers this is the download you need after installing goto windows update and download and install updates
IF YOU ARE USING ROXIO YOU HAVE TO DOWNLOAD THEIR PX ENGINE FIX BUT FIRST UNISTALL ROXIO AND THEN RUN THE ROXIO PX ENGINE FIX AND THEN REINSTTLL THE ROXIO.
Does the Device Mgr list the Cd drive ? if yes...then there is an issue with the SP3 not alloting a proper IRQ to the HW CD drive, is there any issue with the Drive in the Device Manager properties window ?
else
revert back to SP2 after doing a low-level full format...re-install WinXP SP2....
download this from piratebay and try to install WinXP again....
there could be some files missing in you WinXPSP3 CD
this link will downlaod a small Torrent file....to use this u must have Bittorrent software...(downlaod it and install first) then open the small link file...Bittorrent will downlaod the full WinXPSP3 to you PC
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7. Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site: The following products have been designed to be Window 7 compatible (as of January 2010):
Roxio Creator 2010
Roxio Creator 2010 Plus
Roxio Creator 2010 Special Edition
Roxio Creator 2010 PRO
Roxio Easy LP to MP3
Roxio Burn
Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
Windows7 is still being developed and as far as I know it has some compatibility issue with many hardware etc..Check compatibility with manufacture before you look any further.
1. Try to launch Creator Classic to see if it can repair the engine files. a. Double click on the "Roxio Easy Media Creator Home" icon. b. Click "Creator Classic" under the "Applications" section. c. The Windows installer should launch and ask you to insert your installation disc
Try this and see how it works, if it does not, contact me and give me more details
Try This:-
My Computer/Right Click On desired Drive/Properties/Options to autoplay required Types Et,c.
You should also have these Options, In Software Programs Such as Nero Or Roxio Et,c.
about 30 bucks..actually...the first one is usually for entry level, music only work. creator has the ability to burn data cd's and soon, DVD's with a mixing overlap. Nice product actually.
Resolved, unsure what I did but a full re-install of xp and all is working after I did my final windows updates. keep in mind that a fresh install of winxp sp2 with none of 88 recommended patches it still wasnt working
