SOURCE: nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
SOURCE: Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
SOURCE: My Nordictrack treadmill seems to
it is trying to calibrate itself, let it go the whole way up and then down without interrupting it. Then it should be fine.
SOURCE: My Nordictrack commercial 1500 is stuck at 12%
need to flip side and with a wrench 1 / 2 or 9 / 16 loosen the screw of motor base and try to press the down key and if so work you should Lift motor replacement
