Amana PTH153B50AM Air Conditioner Logo
A
Anonymous Posted on Jan 06, 2014
My Amana PTH153B50AM is not heating and everthing looks be working otherwise. Where is the heat reset button on the unit?
Unit is not producing any heat but all the other functions are working and there are not trouble lights. There is a label that says there is a manual reset but I can't find it
4 Related Answers
fixr1st
  • 49 Answers
  • Posted on Nov 18, 2007
SOURCE: Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Anonymous
  • 10 Answers
  • Posted on Jan 18, 2011
SOURCE: Amana PTH153B50AM AC works, heat doesn't. Is
there might be a reset button on the heat protector / you just might have a bad heat protector or the sensor on the board could be burnt out
Joe A H.
  • 185 Answers
  • Posted on Feb 12, 2011
SOURCE: I have an Amana PTAC
First unplug the unit......Take the front cover off, take the wire screen off where the front fan is there is 4 or 5 screws that hold the plate that was under the screen. The electric heating elements are under that plate between the evaporator coil and the front blower wheel. It will lift straight up and give you access to the elements. In the electric heating element area there is a limit switch with a red or black button in the center of it push it to reset the limit it is on the right hand side by the controls. I wish I could find a picture to show you but I couldn't find one. It is not easy to get to... Hope this helps.
Anonymous
  • 3 Answers
  • Posted on Nov 06, 2011
SOURCE: Amana PTAC
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
Amana DigiSmart PTH153B50AM 14000 BTU Heat Pump. What Amana model replaces PTH153B50AM please?
Question edited for a lot more clarity.
The new improved energy efficient versions.
The Improved Amana R-410A PTAC Unit Uses Less Energy
Amana PTAC https://www.amana-ptac.com > products > ptac
Looking to buy an energy-efficient PTAC unit for your building? Buy the new Amana R-410A PTAC unit heat pump, which reduces energy consumption by 35%.
Probably this one. Talk to your installer.
https://www.amana-ptac.com/products/ptac/hec154j
2answers
Amana PTH153B50AM PTAC where the heat runs intermittently.
i'm not familiar with your specific unit but ..sounds like an electronic gas value has gone bad or has a bad connection when that happened to my friend it wasn't that expensive to have it fixed .. BYW it acted like this for a while then stopped working completely
2answers
My AMANA PTAC unit model # PTH093b35ae is not producing heat. My air conditioner works fine. So, I get cold air. However, when I switch to heat, it still runs but does not produce any heat.
It is not switching from cooling into heating. You probably need to have a service tech look at the unit. Sorry. It could be control board or stuck reversing valve.
1helpful
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
1helpful
I have an Amana PTAC unit model no. PTH153B50AM. It will not heat, but the fan runs continuously in the heat mode. The unit has a label that says it has a manual reset for the heater, but no direction as...
Only blowing out cold air on heat
Keep temp 30 degree and mode button in " Heat" Wait for 3 minutes. still problem, check heater-element/RV/Heater sensor.
2helpful
My unit just started blowing out cold air only when set on heat, what is wrong?
its on a lockout. there is a safety switch that is open do you have a multimeter? If not iside the furnace is a red reset push button if you push that chances are you had flame rollout and you need to call the experts that means either you have a cracked heat exchanger or a blocked or not working inducer
My unit just started blowing cold air only when its on heat, what can i do??
To getproper heat, keep your temp setting at 30+ degree and also mode in "heat "position.If still no heat, check your heating sensor for closed circuit by an OHMsmetre.It it's with RV, check power to RV
Amana PTH153B50AM AC works, heat doesn't. Is there a reset?
2answers
Amana PTAC
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
