I am having troubles starting my computer. I think resetting the BIOS should fix the problem. How do I do this?
SOURCE: Fujitsu T3010D Bios Password
I don't know if this could help, but here is a BIOS download: http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/download_bios.jsp?service=UK
SOURCE: I can't reset to default bios
hello, you will need to open your system unit, you will find a battery inside the motherboard remove the battery and refix it back. all the information on the bios will be cleared.
SOURCE: forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
SOURCE: how can i reset the bios password for Visual Land VL760 notebook
u can use bios password reset tool
SOURCE: lenovo g530 4151 - restore bios from USB or CD ?
Hi, What I would best sugget you if you this kind of issue is to restore your system to its original settings, just look for the small button just beside the power button on your keyboard, it has an arching arrow logo, that key is what we called One Key Recovery that would restore your system to its original factory settings. but just a hint it would also delete everything on your computer so consider bucking up every important files taht you have before proceeding with the recovery. also make sure that the ac adapter is plugin before you press the one key recovery button then it will give the options to choose from, just choose one key recovey then proceed with the factory default recovery, thats it it would now proceed with the system factory default restoration. If you still need some clarifications regarding this issue you could also call the tech support hotline of lenovo
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-
6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope that helps you.
