I have a Red Horse Troy Bilt tiller. The wheels turn but not the tines. The trouble shooting section indicates that I should adjust the PTO/Clutch but does not give directions to do so. Any advice? The tiller is less that 2 years old.
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
have you ever taken off the rear tines gearbox? Try taking it off and see what condition the clutch is in. I haven't looked at mine recently, but I think you just add shims to increase the clutch tooth engagement. Matt
