SOURCE: SES light then Reduced engine power light, loss of engine power
Hi It me Mohammad Siddiq my dear. First of all it will be wise of use to take your vehicle to a dealership or any other fully equipped w/shop. They can better tell you what the fault your vehicle has. But at the same time if your friend has the same model vehicle so you can exchange some parts with that vegicle, e.g., Mass Air Flow or TPS (Throttle Position Sensor) and can check your vehicle. These parts do not need to be programmed with scan tool. Just Simply replace these parts and switch on the ignition and wait for 01 minute, then switch off for 30 seconds and then start the engine. Now road test your vehicle, if no SES light or reduced power then there was fault with the part/s replaced. So Return those parts and now you must replace these parts with new or used ones. Anything else I may be contacted on my yahoo id [email protected]. Thanks. I am an auto technician and working in a GM dealership in Saudi Arabia. I am from Pakistan.
SOURCE: The reduced engine power light came on my 2003 GMC
If you live near an Autozone, they can diagnose your code for free. This is gm's attempt to protect the engine from worse damage by limiting the power output of the motor...
it could be major, could be as minor as a gas pedal sensor...
get the code..
SOURCE: 2002 gmc envoy check engine and reduce engine
typical causes: dirty air filter, clogged up catalytic converter
SOURCE: What does reduced engine power light mean
this model has what they call fly by wire.. no accelerator cable. If the computer detects a problem in the thottle system it will not allow the engine to accelerate and will show reduced power and possibly set a check engine light. The dealer usually wants to replace the throttle assembly which is very expensive and usually un nessesary.
I have had a lot of succes with just cleaning the throttle plates real good.
SOURCE: 2009 chevy silverado traction control
DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
Your vehicle has an electronic throttle body unit so it uses voltage signals to control throttle blade in the throttle body. There are a few different issues that can cause this problem.
First off there is a update for the PCM to address those codes, but you will have to take it to the dealer for that.
Second there is issues with the actuator on the throttle body binding up and causing the codes.
Third there is a yellow wire coming off the throttle body connector that breaks inside internally and cannot be seen to the naked eye. The best way to test that is to grab the wire about 5 inches from the connector and tug if it feels spongy or breaks, that
