2009 Chevrolet Chevrolet Malibu LT Logo
J
James Davis Posted on Jan 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Steering wheel controls do not work on radio
Radio removed and reinstalled. Did not theft lock. Radio and Bluetooth work, but not steering wheel controls.
William R Wentzel Jr
Level 2:
Scholar:
  • Expert 137 Answers
  • Posted on Jul 11, 2014
Expert
Level 2:
Scholar:
Answers
137
Questions
Helped
26580
Points
307
By Who?
Was the Battery disconnected? in the Process?
Sounds Like a possible short in the Sound contrl Module
Steering controls on 18 Honda Civic do not work. I cant turn the volume up or answer calls from steering controls.
get a meter and start checking the harness with the connectors from radio to steering controls
MY LOW BEAM LIGHTS, BREAK LIGHTS AND RADIO SOUND CONTROL ON STEERING WHEEL, ALL STOPPED WOKING
Steering wheel radio controls and horn not working - Jeep Wrangler ...
www.wranglerforum.com/.../steering-wheel-radio-controls-and-horn-not...
Sep 22, 2014 - 12 posts - ‎6 authors
... 2Dr sport and my step/reset buttons, radio control and horn all stopped working. ... Also the lights behind the step/reset and cruise control went out, but the ... Soundslike a bad clock spring ribbon cable in the steering wheel. steering wheel buttons not working
Jun 14, 2012
Steering wheel audio controls
Mar 5, 2011
More results from www.wranglerforum.com
Why don't steering wheel controls work?
Check wiring for unplugged plugs might try removing radio again to look real good for problems also radio might not be compatible even though it is ford
Hope this helps :-)
Why do my seek button, power button and the bluetooth not work
Are these on the radio itself or on the steering wheel? If the radio, you may need to pull the radio fuse (Warning! This will delete any and all saved Bluetooth devices, radio station presets, clock, eq settings, bal and fade settings, etc) and then try it again. If the issue is with the steering wheel controls, and you have an aftermarket radio most often you will need an adapter to connect the new radio to the steering wheel as well as a radio that has that capability.
Radio out
Ensure that the unit you've used comes from a vehicle with steering wheel controls. If it's a aftermarket radio additional hardware is needed. Metra SWC-1 is often used.
1helpful
Steering wheel controls not working
If the radio works from the dash then unlikely to be a fuse. need to remove the steering shroud just behind the steering wheel and check for any loose connections is where I would start.
Remove ignition lock to switch link 1995 suburban
The ignition lock assembly contains two components: a lock cylinder to deter theft and an electrical portion that supplies power to electrical components such as the radio, electric windows, and windshield wipers. The electrical portion of the ignition switch also provides power to the starter motor to start the engine.
The ignition lock is an anti-theft device that prevents a vehicle from being driven unless the ignition key is in the ignition switch. If the ignition key is not in the ignition switch, it 's impossible to turn the steering wheel.
To replace the ignition switch cylinder lock, the trim panels around the steering wheel are removed. Then the tamper-proof hardware that attaches the ignition lock assembly to the steering column is removed. The ignition lock assembly is removed from the steering column, and the lock cylinder is replaced. The new ignition lock is reattached to the steering column, and the trim panels are replaced.make sure you dissconect battery first the 1997 had a recall on the ignition switch dont no if the 1995 had a recall if so they will replace for free
3answers
The controls on the steering wheel stopped working and the radio doesnt work either
Replace the clock spring under steering wheel, if applicable to your vehicle
Remove steering wheel with a radio control next to it
Try: slightly wiggle sideways, and driver's face
Steering Wheel Control
I installed a body lift and now none of my steering wheel controls dont work any ideas
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
