Baumatic 23 in. BDW13 Built-in Dishwasher Logo
Posted on May 24, 2009
Error code E2
Baumatic BDW13 built-in dishwasher giving error code E2. Please help!
  • Anonymous Mar 27, 2014
    Error code E2
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4869
Points
13
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
My dishwasher will not start and the plates light keeps flashing, what does this mean and what can I do to fix this. Thanks
Here is a link to the error codes for your washer. http://www.manualslib.com/manual/213875/Baumatic-Bdw13.html?page=25
Also, another link to an incredible source of info on a whole host of manufacturers' diagnostic routines--your model is on page 19, includes how to enter diagnostic mode, etc. I hope this helps you!
8helpful
2answers
Error code on my bdw13 dishwasher
Turn off the water and electric!
Its really easy to change the heater element, once you have taken out the dishwasher!, remove the bottom panel and remove the wiring to the element, slacken off the nut under the electrical contacts voila!, also it may be a faulty thermostat that you cannot reset and has to be replaced, I would do this at the same time, as again its easy with the bottom off.
Bumatic dishwasher bdw13 showing error code 1
Ok I think I can really help you here.
This is your error code, sounds like it has problems filling, might also be blocked.
‘E1’ LONGER FILL TIME. FAUCET IS NOT OPENED.
Ensure that inlet hose is not
kinked or crushed
Found the online manual for this model, it is a PDF file so you will need 'Adobe Reader' to read it. (click on link)
http://www.tlc-direct.co.uk/Technical/DataSheets/Baumatic_Manuals/BMBDW13.pdf
That should help you
Bri
Dont know how to clean the dishwasher
go to the dishwashers brand site,click help for your solution.
1helpful
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
6helpful
Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
4answers
I need to reset my dishwasher but don't know how!!
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Top Baumatic Dishwashers Experts
Mike Cairns
Mike Cairns
john h
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
