Call Moultire you will need equipment to with you to troubleshoot the issue. to get help number to call is 8006533334 option 1 and 1 to speak to live person
If you have forgotten to set date and time then you can also set date and time after turned on the camera. to set date and time follow the given instructions:
Press the Menu button on the rear of the device, then choose Set with left or right button, Then go to Setup menu.
Select Option followed by time icon. This brings up the date display. The display blinks as it has not yet been set.
With the help of Right or left buttons select Year, Month, Day,Hour or Minute. Then press Menu/Ok button after the settings completed. Now every picture captured with the Fujifilm FinePix F460 will save the date and time to the pictures
I hope this solution helps you For further assistance, I am here to help. Thanks and Keep Visiting FixYa
hi i hav a problem with my tv.if i switch it on i have a black screen dats fades away after a while with small black dots on the screen but da piture is clear
is ur batt healthy-must hav 12V at all times-cause its a coil ignition-is the regulator workin to charge it? carbs r a touchy thing-mite want to inspec low speed or idle jet-do u hav a manual*
You didn't mention the spark plugs.Did you replace them?Check also for strong spark on the cables.Unscrew the spark plug's plug from the cable and keep the edge of the cable about half an inch from the engine (aim a bolt usually near the cylinder's head) and with the kill switch "ON" press the start motor's button and you should see a blue thick spark. Also check for normal fuel flow from the tank to the carbs.Change a fuel filter if necessary.
some times their is not enough space in phone memory! if you hav any pic or video in phone memory! move memory card or pc! then you can download songs! actually one songs is 3mb! check phone memory
