HP Master
- Posted on May 24, 2009
Re: HP C7280 Printer not priting wirelessly.
Solution
Replace the indicated ink cartridge(s), or press
OK
on the control panel to continue.
HP recommends the use of genuine HP ink cartridges. Genuine HP ink
cartridges are designed and tested with HP printers to help produce
great results, time after time.
NOTE:
HP
cannot guarantee the quality or reliability of non-HP ink. Printer
service or repairs required as a result of printer failure or damage
due to the use of non-HP ink will not be covered under warranty.
Follow these steps to replace the depleted HP ink cartridge(s).
Step one: Replace the indicated cartridge(s)
Make sure the HP All-in-One is turned on.
NOTE:
The Attention light blinks when the product is turned on.
Open the access door by lifting from the front center of the HP All-in-One, until the door
locks into place.
Figure 1: Opening the access door
Squeeze the bottom of the latch below the ink cartridge to replace, and then
lift the latch.
To replace the black ink cartridge, lift the latch on the far left.
To replace one of the five color ink cartridges, such as yellow, light cyan
(blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center
area.
Figure 2: Lifting the latch
1 - Ink cartridge latch for the black ink cartridge
2 - Ink cartridge latches for the color ink cartridges
Pull the ink cartridge towards you out of its slot to remove it.
Figure 3: Removing theHP C7280 Printer not priting wirelessly. - c01079716.jpge
Remove the new ink cartridge from its packaging.
Holding the new ink cartridge by the handle,
push the ink cartridge into the empty slot.
Match the color and pattern of the ink cartridge to the color and pattern on the print
carriage.
HP C7280 Printer not priting wirelessly. - c01079717.jpg Figure 4: Inserting the new cartridge
HP C7280 Printer not priting wirelessly. - c01079718.jpg/li>
Close the latch, and make sure it is secure.
HP C7280 Printer not priting wirelessly. - c01079719.jpg Close the access door.
Figure 5: Closing the access door
Step two: Align the new ink cartridge(s)
Make sure paper is
loaded in the input tray, and then press the
OK
button.
The HP All-in-One prints the alignment page, aligns the printhead, and
initializes the ink cartridges. This takes approximately 5 minutes.
CAUTION:
Do not disconnect or turn off the
HP All-in-One during this time. You may hear the
HP All-in-One making noises.
Check the display for status, and then press
the
OK
button. Recycle or discard the alignment page.
Cause
The original HP ink in the indicated ink cartridge(s) has been depleted.
