Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Need ZE-215 heater switch for a twinstar electric fire place unit
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 48 Answers
You can buy Zing Ear ZE-215 from this website: https://www.ceilingfanswitch.com/product/ze-215-lighted-rocker-switch
Posted on Nov 10, 2018
SOURCE:
I really need to know where I can get a slide switch ze-209s-3 for my tacwise
Morning Pat,
Have you tried the place that you bought it form? By the sounds of it, this may be an old model? look at my link and I'll ask the question for you. Leigh Co Limited
Jan 20, 2015 | Electric Tools & Hardware - Others
We have a electric fire place and need a on off switch replace part ZE215 model 33E05
At link below. Ignore picture shown at link.
PH30-16740 =Carling LRA911C neon lighted 16A-125VAC 1/4" blade terminal 1/2" x 1-1/8"
Ceiling Fan Speed and Light Switches at Ken Electronics Kalamazoo...
Oct 22, 2014 | Home
Need twinstar circuit board model 28e05-r pt #pro-082a
Bad news company...5 year old $500.00 device and the control board failed. NO parts...offered to sell me a new insert..No way Jose
Jan 17, 2014 | Leisure HOMEPRIDE Electric Fireplace...
Electric fire place switches itself off. Why ?
If it only switches itself off when the heater is turned on, it is most likely an overheat-temp-sensor that is doing it. If you have had the fireplace for over a year, you may want to do a complete clean/vacuum etc of the unit. A decrease in airflow can lead to the temp sensor tripping. If that does not work, you should contact the dealer for service.
Mar 08, 2013 | Heating & Cooling
Furnace lights right up, but will not shut off with on-off switch or thermastat switch? checked out the thermastat switch and that works fine.
Disconnect the thermostat wires from the gas valve, if unit still runs; you have a short in the gas valve and it needs to be replaced.
Feb 22, 2011 | Empire DV-215 Direct Vent Natural Gas...
NEED AN ON OFF SWICH FOR A TWINSTAR ELECTRIC FIREPLACE HEATER SWITCH PART NUMKBER IS SR22N
If your On-Off is not working ? Go to GRAINGER and get Light Rocker Switch SPST,3 connections 2VLN1 or the Light Rocker Switch SPST, connections 1A824
both will do the job.
Nov 12, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Fire place insert light replacementht
Dimplex has discontinued use of the remotecontrol unit you have requested; therefore we are no longer able to providethis as a replacement part. In order to operate your unit please plugyour power cord directly into your wall outlet and operate the stove via themanual switches.
Aug 20, 2009 | Dimplex Compact Electric Flame Stove...
Swith wont work with charmglow fireplace
http://www.kenselectronics.com/lists/switches.htm
Your most likely using the wrong switch. Try the link above for the correct switch. Its a single pole 15A 125V rated switch. There are 3 terminals, the third is for the light in the switch and is a neutral wire for the indicator light only. The wires must be correctly on the terminals or else you'll create a dead short! On the link above your looking for the replacement of the ZE-215.
Nov 13, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
267 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
