I have look at you tube videos etc it stats to use a screwdriver for help remove it I cannot get the silver mount to budge is there anything else I can do?
I have a GFC525F and that mounting ring is like glue on that disposal. WD40 does nothing. I was just told that BLASTER from Autozone should work! You need more than a lube. You need a catalyst Remover. I will have to have good ventilation because there are tons of dangerous warnings listed on the can, but this may work.. I will try it soon!!!!! I may try while still attatched to pipes to assist small plastic ring that locks under sink but i don't want to break the pipes. I really hope this works...i may go with another brand if i get this disposal off. I DONNOT LIKE GE MOUNTING RING WITH TIGHTENING EARS!!!!! Too much trouble!!!!
Try some wd40 or a lube of some kind.
Usually it is on very tight to prevent movement.
