Question about Goldstar DH504ELY6 Dehumidifier w/ 50 Pints Per Hour Capacity
Stopped working no motor or compressor sound
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Does it act the same as if the bucket was removed? Likely your fill bucket switch is not connecting. Remove the bucket, press the switch and try to run the unit. If it powers up and "works" then you need to make sure the bucket has a good connection with the switch. If this did not work, remove the connectors to the switch and electrical tape them together and try running this again. If it works, your switch is bad. Replace. If you leave it electrical tape connected, the unit will not turn off when the bucket is full.
Posted on Jan 13, 2014
SOURCE:
My HDN455E dehumidifier stopped working the other night. When I turn the knob to "on", it makes a clicking noise, but does not turn on. The plug works fine, there is no water in the bucket, and I've...
check the capacitor to the conpressor motor BUT IF YOU ARE A NOVICE STAY AWAY FROM THIS PART IT CAN BLIND YOU OR EVEN KILL YOU and its not worth that Truely its sounds like the capacitor is shot or ven worse your compressor mother is shot have a technition check it out it is really worth it. PS Im not jocking about the capacitor.
Aug 18, 2010 | Haier HDN455E Dehumidifier
Fan stopped running but it sounds like the compressor is still trying to operate.
Eather the fan motor is going bad or the cap is try changing the cap first, if not the motor.
Jul 17, 2010 | Kenmore 54701 Dehumidifier
Stopped operation...fan does not work...compressor get's very hot
It is very normal for the compressor to get very hot, almost to the point of being able to fry an egg on it. So it is important to keep everything clean and dirt, dustfree. Clean the fan blades, tubing and anything that you can do to ensure good air flow.
Apr 08, 2010 | Goldstar DH504EL Dehumidifier
I am having Daewoo refrigerator Model DIR220. When I switch on the refrigerator the compressor starts after about 3minuites and stops in few seconds. fan motor works continuously. As the compressor stops...
the compressor has an internal overload to protect it from overheating. the compressor is cooled by the refrigerant passing over it. It could be a bad compressor,, bad charge of refrigerant, or simply dirty coils not allowing air movement
Nov 26, 2009 | Dehumidifiers
I borrowed a Fedders dehumidifier, Model # A7DH45B2AA-R from my neighbors. It worked beautifully for a few weeks, extracting a full container about each 24 hours. All of a sudden, it stopped extracting...
oh no it sounds like the compressor is not working, can you hear it kick on? or the freon may have leaked out. the air coming out should be warm at least. are the back side coils getting cold? you may have to take it in
Oct 14, 2009 | Dehumidifiers
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
Makinga chirping sound does not produce any condensate. Cleaned filter cannot remove front to access coils
MAKE SURE THERE IS NO ICE FORMING ON COILS IF U CAN SEE THEM. IF IN BASEMENT,
SURROUNDING TEMP MUST BE ABOVE APPROX 60 DEG. ALSO, TRY ADJUSTING THERMOSTAT
Jul 01, 2009 | Kenmore 54501 Dehumidifier
Kenmore 54701
Yes, the fan motor should come on when you start the unit.
I just came from my basement where i had the same problem.  My fan was not working- it was noisy at first, then it stopped working.  it seems the motor has some play in it and came out of the electromagnetic housing that should make it spin.  once it was slightly out , it no longer spinned.   I took it apart, and then reassembled it nice and tight.  there is still some play, but it is working great.  If it happens again i may try to get a replacement motor.
Oct 02, 2007 | Kenmore 54701 Dehumidifier
Doesn't want to stay on...
Most likely the fan motor has broken. Without the fan, the compressor will overheat. There is a safety device inside that automatically shuts off the compressor to keep the overheating from destroying it. Check to see if you can feel air movement in the front or back of the unit while it is running. If not, then the fan motor has definitely broke. I had this exact problem on mine.
If you take the unit apart, you will find a parts list inside the unit. It will be inside a small plastic pouch. You can order a new fan motor from Sears. The cost is $30 plus shipping.
You will have to move the condensing coil in the front out a bit in order to exchange the motors. Just be careful not to break any of the copper lines. They are copper so they will flex quite a bit without breaking. Still, use caution. If you break the lines, all the refrigerant will leak out and your unit will be useless.
Sep 01, 2007 | Kenmore 54501 Dehumidifier
Goldstar DH504ELY6 Dehumidifier w/ 50 Pints Per Hour Capacity Logo
119 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Paul
Paul
Michael Youngman
Michael Youngman
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
