You receive "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)" or "Stop error code 0x0000008E (KERNEL_MODE_EXCEPTION_NOT_HANDLED)" when you restart a Windows XP-based computer
Back to the top ' Give Feedback
error on windows xp desktop page_fault_in_nonpage_ - 20x20_grey_minus.pngmages/20x20_grey_minus.png" alt="20x20_grey_minus.png" class="h_mi" />954211 MS08-061: Vulnerabilities in Windows kernel could allow elevation of privilege
SOURCE: Blue Screen with various STOP error messages appearing.
This is a tough one to troubleshoot since there are several issues which can result in this error. Let me start by listing known causes.
Corrupt pagefile.sys file
Corrupt or wrong drivers for system devices. printer, camera, ect.
Corrupt program drivers, adobe elements, capture card software.
Bad System Ram Modules.
You didn't specify if you installed anything new, hardware or software but to trouble shoot this issue begin by download Memtest86. This will test your system boards memory for errors.
If your ram passes the test you might try removing other devices such as printers and its software. Testing the issue after each uninstall.
Last you can try replacing system files or performing a system repair using your operating system cd. If you need to run the repair option and need help just post back here.
Hope this helps.
SOURCE: my hp wont boot up keep getting blue screen error
Good chances are, you have a bad memory stick. If you have 2 memory sticks installed, take one out. If it still does it, put that memory stick back in and pull out the other one. If you're still having problems, you might have to reinstall windows.
SOURCE: where should I look in the computer (Dell
Hi friend,
You need to check your ram in your computer.. i think your RAM is not good running...so try to change then ram ...then it will work..
