Question about Jura Capresso Impressa E75 Espresso & Coffee Maker
No coffee will dispenses
It goes through the cycle but no coffee come out. It all ends up in the tray. As described, the coffee is ground and the machine seems to go through its usual cycles however the unused (dry) grounds are dropped into the grounds collector and the water into the bin. I have also tried using pre-ground coffee and have experienced the same results.
Jura customer service agents act bery surprised by this problem and suggest sliding the moveable coffee dispensing head up and down firmly to try to jog-free anything that may be clogging the system. After doing so, they suggest running through a manual rinse cycle to see if anything comes out of the heads. Typically there are some grounds that make their way through. Sometimes this technique works and more often it does not. I have now wasted enough coffee to try to find a sustainable solution. I was wondering if you have solved your problem, as we have the same now. The coffee and the rinse goes straight in the tray. Please let me know what the outcome was. Thanks
  • venice298 May 25, 2009
    Thank you for you comment, however it is not possible to remove the spout, without opening up the coffee machine. I wonder if I should try it, I think it might be a blockage.
    President:
  • 1,618 Answers
I would remove the coffee spout and check the lines into it. The coffee seems to stop when it hits the spout and goes through the by pass instead. Remove the spout(be careful) then run a coffee and see if it works.
Posted on May 24, 2009
  • Ernest R
    Ernest R May 26, 2009
    If the machine is still under warranty, send it back ti Jura. If not your options are to find a tech in your area or open the spout. Send me a few picture of the front of the machine especially the spout from all angles and I will give you the easiest way to remove it. I have repaired the X90 but have never seen the spout on your model, the pictures will help.
SOURCE:
I have a saeco super automatica Leaking water
Take the brew unit out when the machine is off and cold. With your finger, check the well next to the large gear on the inside of the machine. This is the gear that fits in the back of the brew unit when it is in place. That well may be clogged with fine coffee grounds and some mildew build up. You might notice that after brewing, very little water will has been flowing into the drip tray. Take a Q-tip and push it through the hole at the bottom of the well to remove the coffee ground buildup. The excess water after brewing will flow through normally now and not behind the brew unit.
Mar 02, 2017 | Saeco Coffee Makers & Espresso Machines
I cannot get the drawer to close completely on my Jura E8 in order for the "missing drawer" light to go off. I've unplugged the unit to allow chip to reset... nothing. I think the elevator is...
I have the same machine and this seems to happen if the grounds bin is pulled out before it goes through a full cycle. take both the grounds and water trays out. Try to fit the grounds bin around the "elevator", slide the grounds tray underneath that then the water tray as well. It should slide right in then the machine will complete the cycle and work just fine :)
Feb 06, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Tray will not insert properly, a flap seems to be lowered
Start up the machine, take insert everything but the used grounds container. The machine will reposition the brew unit. When the machine says "heating", take out the tray and now you can insert everthing with the used grounds container. You can of course run a Rinse cycle if the machine doesn`t start positioning right away.
Aug 30, 2009 | Jura Capresso Impressa F9 Espresso Machine
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
How fine have you got you grind setting, if it is a new machine it needs to be on course Grind, fine grinds clog the filter.  You need to reach into where the tray goes with a cloth and wipe clean the filter bin which is right behind a flap
Nov 02, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Cleaning machine propt will not go away
I have the same machine and had the same issue all day yesterday. Tech support will tell you to clean the tamper (round disk behind the tan/gray "flap"), which you should do. That didn't do it for me, however, so I kept cleaning. I cleaned out the chute where coffee powder goes. Then, after turning off the machine and removing the tray, I used my fingers to go up/under/behind as much as I could get to. I found the motherload of old coffee grounds. It's hard to describe where, but it was all around that metal area in the center. Just keep poking, but use your fingers so you can feel where the coffee is. I tried q-tips, but that didn't work..you have to feel it. After I got all the gunk out, I ran a cleaning again - no tablet - and it no longer said "press rinse" at the end of the cycle. It asked me to dump the tray, and then it went to "ready"! Yahoo - saved a bundle in shipping and repair.
Sep 27, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Leaking water and coffee grounds behind and below drip tray at end of brew cycle
If you take off the top and start your machine you will see and hear if the boiler leak, try this first to work around your problem.
Let me know if i can help you more.
Best regards
/Mirran
Sep 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
1,051 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
