Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
SOURCE: Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
SOURCE: White screen only on Sanyo DP26648
Your reported symptoms are odd in that most failures are related to the primary power supply but that takes down both audio and video.
The backlight is obviously working (white screen) but it is no longer receiving any video information and this points to a failure of the logic (or the output of the power supply that services logic) used to control pixels on the screen.
Some screens have the majority of the control ICs actually mounted on the LCD assembly and because of very close pin distances used on dense ICs, they are often not replaceable by hand since they were installed by robotics.
I would first suspect (and hope for) the logic voltage output of the power supply to be the culprit.
If any of you posters have had a repair done and received any kind of a detailed report (you should), would you be kind enough to post it back as a comment to this original message?
SOURCE: olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
